Edge EZ and TST stacked?
Old Apr 12, 2007 | 03:37 PM
chadder1313's Avatar
Ok, i have a 01 2500 6 speed. Im in the process of getting the Edge Ez and TST modules along with gauges. I do have a 4" exhaust and K&N intake. Now i do have a stock clutch and stock turbo for now but that will change soon. My question is this a good set-up right off the bat.
Old Apr 12, 2007 | 04:07 PM
Moose10's Avatar
I'm waiting for my buddy's old EZ to get here. It'll be stacked with my TST PM3 Comp and we'll see how that works. My stock clutch has been holding up good as far as I can tell, but I'm usually pretty easy on it. The only time I really get into it is when I'm already moving in 4th or 5th
You'll like the TST ! It's a real kick in the pants....I can't wait to drive her with a good clutch, injectors, and bigger turbo....whoo, hooo !!!
Old Apr 12, 2007 | 08:11 PM
AggieJustin's Avatar
That's a good setup. You'll find a lot of people running the TST/Smarty stack which is similar, it just uses the Smarty for timing and low-end fueling vs the EZ. On the upper levels, be prepared to find the limits of your stock clutch. Some have lasted longer than others, but mine didn't even make it with just the EZ.
Old Apr 14, 2007 | 06:26 PM
Thanks guys!! I didnt doubt it was a good set-up but i justed wanted to hear from guys that have a simular type set up. I cant wait!!
Old Apr 14, 2007 | 06:32 PM
jd4440's Avatar
Just did the stack and it is awesome but i need a turbo it gets hot
Old Apr 18, 2007 | 05:29 PM
Well i just got my truck back and that stack is awesome. I would reccomend it.
Old Apr 18, 2007 | 07:04 PM
natew05's Avatar
i am running this on my truck and my turbo does not run too extremely hot though, right now i can run the stack caus i have no fass system
Old Apr 18, 2007 | 11:11 PM
Ph4tty's Avatar
Get a clutch and start saving for injectors and a turbo- thats where the fun really begins. If you think about it a set of sticks can add another engine's worth of power
Old Apr 19, 2007 | 06:15 AM
Thats what i got in mind!!
Old Apr 19, 2007 | 07:34 AM
Justin26's Avatar
That was a great stack on my 01. The only problem was I went through two injection pumps while doing this. Just make sure you have gauges!
Old Apr 19, 2007 | 03:54 PM
Im going to take it easy on her. But i do know eventually the VP will go out. But for now im gonna baby it.
Old Apr 19, 2007 | 04:26 PM
natew05's Avatar
Just make sure you have a fass system or something similar to that and your injection pump won't go out twice, that could get kind of expensive. i agree with the gagues though good investment
Old Apr 19, 2007 | 07:03 PM
I had a set of AutoMeter gauges installed with EGTs, boost, and fuel pressure. I got my eye on her!!
TheOutlaw
23
Sep 8, 2007 01:44 PM
Big Blue24
Feb 25, 2007 04:32 AM
mooseman
Oct 29, 2004 12:06 AM
mooseman
Oct 13, 2004 04:06 PM
BLUTIC
16
Mar 13, 2004 06:39 PM
