Edge EZ installation questions
Old May 13, 2003 | 02:20 PM
kstrongsyj's Avatar
I have an dedge EZ I am puttin in this weekend. Everything appears easy enough......accept this turnbuckle thing Anybody got a pic for me of how the turnbuckle attachs and where? I was talkin with Edge products and now i think I am more confused than ever
Old May 13, 2003 | 02:36 PM
kstrongsyj's Avatar
Re:Edge EZ installation questions
Never mind.....I found one ;D<br><br>
Old May 13, 2003 | 02:44 PM
kstrongsyj's Avatar
Next question ??? I have an 01 with Manual....do I even need this? And what is the brass fitting described on the edge website that enables greater than 20 psi boost? It is listed under the automatic section, but says 2001 autos will not have them. My manual does....so do I need that brass fitting since I did not get one with my ez? Did that even make sense? Here is the link to what I am talking about:
http://www.edgeproducts.com/EZ-Instructions.html
Old May 13, 2003 | 02:47 PM
geer's Avatar
I have the comp and received the brass elbow with the kit. I f you have an manual you shouldn't need the wastegate hook. I know my 2002 six speed didn't. The elbow will give you more boost.<br>Scooter
Old May 13, 2003 | 03:17 PM
kstrongsyj's Avatar
thats what I thought. So the turnbuckle is just for the autos, where the brass elbow should be for either application? I need the brass elbow then [undecided]
Old May 13, 2003 | 03:22 PM
phox_mulder's Avatar
If you didn't get an elbow with your EZ, just call Edge, they should send you one no problem.<br><br>The brass elbow only works on the Turbo supplied with the manual transmission trucks.<br><br>The turnbuckle can be used on either, but has to be used on the Automatic Transmission trucks, due to a hardline wastegate that isn't elbow-able.<br><br>phox
Old May 13, 2003 | 03:48 PM
TXRAM2's Avatar
Phox, very well put ;D
Old May 13, 2003 | 04:16 PM
BigBlue's Avatar
[quote author=phox_mulder link=board=4;threadid=14671;start=0#137683 date=1052857342]<br>elbow-able.<br><br>[/quote]<br><br>Is that even a word?
Old May 13, 2003 | 05:22 PM
Shovelhead's Avatar
Administrator / Scooter Bum
[quote author=BigBlue link=board=4;threadid=14671;start=0#137702 date=1052860563]<br>[quote author=phox_mulder link=board=4;threadid=14671;start=0#137683 date=1052857342]<br>elbow-able.<br><br>[/quote]<br><br>Is that even a word? <br>[/quote]<br><br>It is now.
Old May 13, 2003 | 10:22 PM
rattle_rattle's Avatar
Just a word or two about the boost elbow...<br><br>If you install the boost elbow at the time you install the EZ all will be well. If you decide to remove the EZ to take the truck in for warranty service, if the elbow is left in, it'll set a code for overboost. The EZ has a boost-fooler built in. Save the old fitting in case you need to downgrade later.
Old May 14, 2003 | 10:39 AM
kstrongsyj's Avatar
thanks for the advice....I am way out of warranty already anyway though
Mr.Dodgeman
Mar 27, 2006 01:26 PM
Brad Gray
16
Apr 20, 2004 02:09 PM
PADZZ
Dec 31, 2003 06:23 PM
Chris_O
Sep 19, 2003 07:02 AM
