Edge EZ
Old Jul 5, 2004 | 09:37 PM
farmer dave's Avatar
Edge EZ
I just got an EZ off of a freind for cheap, $225. Got it hooked up and took it for a drive and WOW!! What a difference it makes. The turbo spools up real quick now and doesn't slow down around 2K. Now if I can just keep out of the throttle maybe my mileage will go up
dave
Old Jul 5, 2004 | 10:35 PM
kevinn's Avatar
I too couldn't believe the difference the EZ made!!!! Here in Utah there is a very long climb out of the Salt Lake Valley and I pull a 24 foot trailer with a lot of water and a heavy 4-wheeler in the back. Last year without the EZ I had the peddle to the floor and just barely kept it in 3rd locked going about 55 - 60 mph. This year with just the EZ and a closed wastegate, I went up it at 70 mph in 3rd locked with 1/2 throttle. I couldn't believe it. I wonder how it will do with the rest of the chip hooked up? (I have the comp in EZ mode currently). I would probably end up on the side of the road with a burned transmission.
Old Jul 5, 2004 | 11:45 PM
crobtex's Avatar
Don't count on the mileage going up. Too obtain economy, you have to keep your foot out of the injector pump..... and that ain't gonna happen with the Edge!
Old Jul 6, 2004 | 02:31 AM
HOHN's Avatar
IF you think the EZ made a difference, try some injectors
Old Jul 6, 2004 | 05:54 PM
phox_mulder's Avatar
I hope you have guages.
I can easily get the EGT up to 1300 with my stock truck going up parleys.
phox
Old Jul 6, 2004 | 10:18 PM
kevinn's Avatar
I do have guages. The EGT is post turbo (I should move it pre-turbo) and without the EZ I was up to around 1000 - 1100. This time, it stayed right at 800 but I'm not sure if that can be attributed to the chip or the open wastegate or if it was just a cooler day.
Old Jul 7, 2004 | 04:24 PM
Probably a little bit of all three.
phox
Old Jul 21, 2004 | 09:14 PM
CRT's Avatar
CRT
Where is the best place to buy a Edge EZ ?
This weekend, I installed a boost gage, trans temp gage. I have the EGT gage , but was not sure where to install it , befor or after the turbo.
Is the elbo a must with the EZ ?
Old Jul 22, 2004 | 12:18 PM
800summit's Avatar
Mount the Pyro pre turbo, The boost elbow is for raising the boost over the stock 20psi it is not a must.
Old Jul 22, 2004 | 12:20 PM
Diesel Dave's Avatar
The elbow is not a must, but it will make a BIG difference with your EGT's.
Old Jul 22, 2004 | 12:36 PM
CRT's Avatar
CRT
it will lower the EGTs? and lower is better ?
Old Jul 22, 2004 | 12:39 PM
Wilson's Avatar
Look in the classifieds or check out the vendors that sponsor this site.
BTW you will not be able to use a boost elbow unless you have a manual transmission. For an automatic you will have to purchase an aftermarket wastegate.
Install Pyro preturbo.
Good luck
Old Jul 22, 2004 | 12:45 PM
RustyJC's Avatar
...or use the turnbuckle trick (required for HY35 turbos only).
Rusty
jwhip
28
May 29, 2005 11:32 AM
rockjeep73
Mar 25, 2005 03:34 AM
Hoss
13
Jun 18, 2004 06:14 PM
powerwagon440
Jan 20, 2003 08:50 PM
