edge comp works
Old Aug 25, 2003 | 10:18 PM
MrDiesel's Avatar
edge comp works
I got the edge comp a few days ago and thought over the fact of trading in for simplier system like the ez, less wires and more stock configured friendly.
Well I could not just let the box sit around now could I. I did the install in about 1 1/2 hours with taking my time. I was nervous about starting it up the first time, but it worked with no eng lights or problems.
Oh my gosh is there a difference in power. ;D ;D ;D I am thrilled with the number 1 setting, very noticeable difference. My max boost psi went from 18 stock to now 28-30 easy. I let off the trottle before I would get into trouble......I wonder if I dare try settings 3-5.
Another happy Edge owner,
Rich
Old Aug 25, 2003 | 10:29 PM
dodgeman01's Avatar
Re:edge comp works
so did you hook up the WIRE also :
DM01
Old Aug 25, 2003 | 10:32 PM
MrDiesel's Avatar
Re:edge comp works
I hooked up everything it came with according to the instructions......and I hope for no problems, I really do drive conservative.......
Rich
Old Aug 25, 2003 | 10:38 PM
geer's Avatar
Re:edge comp works
Try 5x5 once your smile will be huge ;D
Old Aug 25, 2003 | 10:41 PM
phox_mulder's Avatar
Re:edge comp works
[quote author=scooter link=board=7;threadid=18840;start=0#msg176699 date=1061869118]
[/quote]
Till he looks back and sees his transmission lying in the road,
a smoking twisted pile of molten metal and dark brown fluid.
Hope there are some upgrades in it's future.
I'd stick with 1-3, heavy on the 1 for a while.
phox
Old Aug 25, 2003 | 10:44 PM
dodgeman01's Avatar
Re:edge comp works
[quote author=phox_mulder link=board=7;threadid=18840;start=0#msg176700 date=1061869314]
[/quote]
phox
[/quote]
been there that really SUXXXSSS
DM01
Old Aug 25, 2003 | 10:45 PM
geer's Avatar
Re:edge comp works
I understand that. It would just speed up the bomb bug ;D
Old Aug 26, 2003 | 07:04 AM
hellotbone's Avatar
Re:edge comp works
Give it a few shots on 5 its not going to kill it. Level 3 will not hurt your trans anyways.
Old Aug 26, 2003 | 07:29 AM
PourinDiesel's Avatar
Re:edge comp works
Your going to need an aftermarket Valve Body in the least to hold your new found power.
Even just on level 1 your Comp will wear on your tranny at an accelerated rate than when you were stock.
--Justin
Old Aug 26, 2003 | 12:53 PM
MrDiesel's Avatar
Re:edge comp works
Before even buying the Comp, I put in the pillar guages, air box and 4 in exhaust and just a month ago had the tranny valve body out and built with a shift kit and 11.5 quarts of amsoil ATF+4.
You are right though I am nervous about losing a tranny if not careful....
Rich
Old Aug 26, 2003 | 02:36 PM
hellotbone's Avatar
Re:edge comp works
You should be able to jazz her a bit on the comp mine lasted 5 months with dd 2's the comp on 5x5 and the stock trans!
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
