Edge Comp problem
Edge Comp problem
Level 2 and 3 stopped working. It started with level 3 a few days ago, now 2 is gone. 3x3 was a perfect around town level for me. 1 is to soft and I have to baby it on 4 and 5 because my clutch won't hold the power.
Is this is a typical problem?
Only a few weeks. I know some people hate the comp because it's given them problems. Just wondering how common my problem is or if other boxes just flat die.
I'll get it fixed. It's going to suck driving around without a box!
so are you saying there is no differance in 2 and 3?
Like if you had it turned off and while driving turned it back on in say 3 and couldnt tell any differance.?
Edge has excelent customer service I'd call them right away.
801-476-3343
801-476-3343
Check your wite tap connection and make sure it has a good one. If not the COMP will act strange. I just had this problem and it was the connector I use from the install kit. I now have a bluechip diesel cover on the way. Hope this helps. Also check all coneection and clean them as well. JMO.
check the ground connection. but best chance is to call up Edge...
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
