edge comp install question?
Old Dec 25, 2009 | 10:26 PM
kyle_truck_pull's Avatar
Exclamation edge comp install question?
I have a 2002 dodge and im putting on a edge comp box, i put one on a long.... time ago on a 99. Is there a special plug for the map sensor on the 2002 truck because the map sensor is different and i dont have the plug if there is such a thing. thanks!
Old Dec 26, 2009 | 11:13 PM
txarrowhunter's Avatar
The comp box has diffrent wiring harness depending on what the exact year that it was meant for. That's why they are diffrent part# when you purchase one.
Old Dec 28, 2009 | 09:24 AM
Is there a way to get something to make this one work? A long time ago I owned a 99 diesel, I bought a superchips D-box for it, it came with an adapter for the harness for a 2002 truck.
Old Dec 28, 2009 | 03:21 PM
Sea:\>Drive's Avatar
Edge makes an adapter for 2002 truck, but you should have it if you own a 2002 box (they came with them). The programming is slightly different in 01-02 model Comps than older years (different MAP voltages). Contact Edge for the adapter.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
