DSS install ???
Old Apr 22, 2005 | 09:36 PM
caper's Avatar
DSS install ???
Ya know the lock ring you use the punch on, just sitting here looking at it and wondering how it tightens with no threads, instructions say will tighten in either direction????? Also it looks like if you dont get it really tight the shaft will just turn inside the berring when turning truck instead if the berring turning. Anyone make sense of that???
Old Apr 22, 2005 | 09:57 PM
phox_mulder's Avatar
I thought the exact same thing, yet it worked just like they said it would.
phox
Old Apr 22, 2005 | 10:55 PM
Lil Dog's Avatar
Its an eccentric collar. If you look closely at the bearing sleeve the outer surface is machined off center. The ring is also machined off center. When you turn the ring on the bearing sleave the two clamp onto the shaft. Pretty slick.
J-eh
01RAMer
May 29, 2008 09:12 PM
caper
May 8, 2005 11:08 PM
chasmack
Mar 21, 2005 05:35 PM
Turbo Deeezle
Jan 24, 2005 08:41 PM
Sidewinder
0
Jul 6, 2004 09:15 PM
