2001 cummins running hot
Old Apr 22, 2005 | 09:01 AM
wilddog's Avatar
Angry 2001 cummins running hot
my 01 cummins is running hot when I tow up hill. My waste gate has been stuck in the past but I freed it up and it is still doing it. Any suggestions?
Old Apr 22, 2005 | 09:10 AM
Palmetto_kid's Avatar
change your thermostat.
Old Apr 22, 2005 | 09:59 AM
RustyJC's Avatar
Probably one of the following:
1. Thermostat
2. Thermal fan clutch
3. Dirty radiator (oil mist/dirt between front of radiator and back of intercooler)
If it's an automatic, there's every chance that you're pulling the grade with an unlocked torque converter. If that's the case, the HOT transmission fluid will heat up the engine coolant. It would help us analyze your problem if you'd complete your signature so that we'd know some details about your truck.
Rusty
Old Apr 22, 2005 | 01:45 PM
pmtg's Avatar
Re: 2001 cummins running hot
hot water temp? or hot EGTs?
Pat
Old Apr 22, 2005 | 06:15 PM
53 willys's Avatar
1. Thermostat
Rusty
my 01 was number 3.
Old Apr 22, 2005 | 06:57 PM
J BODY's Avatar
I've removed and cleaned three radiators in the last month for the cores being plugged up externally from the beloved oil catch container that they so cleverly put right in the fan wash. Best to remove the radiator and degrease it.....and relocate that bottle.
Old Apr 22, 2005 | 09:23 PM
dieselho's Avatar
Originally posted by 53 ******
my 01 was number 3.
mine was the same as 53 ******. I thought that it was the # 53 block, but apparentley not take it to the car wash and don't over do it. I changed the serpentine belt, thermostat,coolant, and checked the fan clutch. I had the best results with the radiator being blown out! Oh, I don't know how true this is but i have the "good 53" block. Hopefully you do too! Although i haven't put it through the test of summer heat, I think i have this one licked
Old Apr 22, 2005 | 10:29 PM
swimmy's Avatar
I too had radiator cloggage. Had to remove it for cleaning and also relocate the breather bottle. Whole front of the motor was a mess.
Old Apr 23, 2005 | 08:03 AM
Mopar1973man's Avatar
No problem for me anymore... Check out the sig and you can build a good one...
whosdunit
Feb 16, 2019 04:07 PM
Strjock81
16
Dec 12, 2007 09:53 AM
edwinsmith
Apr 14, 2006 03:53 PM
duallydave
Aug 7, 2005 09:38 PM
billuem
Oct 6, 2003 06:05 PM
