Driving along and lost a cylinder?? HELP!!
Old Mar 30, 2009 | 10:34 PM
CapnRam's Avatar
I retorqued my head today at the 500 miles for a new gasket, so had to pull the rockers, well tonight i'm driving down the road and wam all the sudden just starts running like crap and looks like white smoke out the stacks, no power and just sounds like i lost a cylinder, oil looks fine.. could a rocker come lose?? I'm susposed to head to WA on friday.. any ideas.. it was running fine up to this point.. thanks
Capn
Old Mar 30, 2009 | 11:09 PM
Mike D's Avatar
Have you pulled the valve cover yet?
Old Mar 30, 2009 | 11:10 PM
turboguy121's Avatar
remove the valve cover and you will prolly see the problem. let us know what you find.
Old Mar 31, 2009 | 06:08 AM
CapnRam's Avatar
I have not, no garage at my place, did all the work at my bro's. And its crappy as hell out.. so i guess when i get in from work tonight i'll do that. Does it sound like a rocker problem or possibly a blown HG?
Capn
Old Mar 31, 2009 | 06:14 AM
CapnRam's Avatar
Is this the symtoms of losing an injector?
Old Apr 4, 2009 | 07:43 PM
Mike D's Avatar
What happened here CapnRam? Never heard anything back on this issue.
Old Apr 4, 2009 | 08:14 PM
CapnRam's Avatar
Sorry guys, got home late from work on Tuesday, so pulled the VC and there it was, #3 intake jam nut backed off, so the valve bridge was laying next to the valves, the jam nut was in the oil return hole, thank god it was just a little to big to fit, and the cap off the rocker was right next to it.. pulled the pushrod to make sure it wasnt bent, it wasnt, put it back together reset the lash, double checked everything else and put it back together, fired him up and purred like a kitten, just got to WA, and averaged 17.5 mpg running 77mph which is 2100 rpm, adrenaline on 1 and the smarty on fuel and boost.. next weekend the new injectors go in, then the following weekend up to BD for there dyno days.. thanks for all the info.. sorry for the late update..
Capn
Old Apr 4, 2009 | 09:41 PM
Mike D's Avatar
Good to hear everything turned out OK.
AntennaGuy
Sep 13, 2011 09:11 AM
CapnRam
Apr 2, 2009 09:16 PM
the_fox_man4
Dec 29, 2006 08:27 AM
mikmaze
Jun 25, 2006 10:47 AM
daystar
Feb 18, 2004 02:34 PM
