Down pipe question
Old Mar 8, 2005 | 06:06 PM
mkrenn's Avatar
Question Down pipe question
After lookin at my turbo outlet on my 99, its lookes like 3 1/2" right?
Anyhow, is there anyone that sells a 4" adapter plate that can be installed on that turbo? I'm thinkin mine is an HX40. I thought I seen it somewhere. Anyone?
Old Mar 8, 2005 | 06:14 PM
SmokinFive9 4x4's Avatar
Unless you or someone else changed the turbo it should be a HY35 I believe. Not an HX40. Are you looking to change the outlet size on the turbo itself or just adapt a 4" downpipe to it? Dunno if you can change the outlet size but I'm sure most of the exhaust manufacturers make a 4" downpipe that will fit right on it.
Old Mar 8, 2005 | 07:22 PM
MLR1's Avatar
Piers makes an adapter for running an HX40 down pipe on an HX35 http://www.piersdiesel.com/3540Adt.htm . Is that what you are looking for?
Old Mar 9, 2005 | 04:41 AM
2500CTD's Avatar
are the hx and hy the same outlet??
Old Mar 9, 2005 | 05:54 AM
CTD NUT's Avatar
Your 99 Auto has a HX35, not a HY, stock........HY's were on 00 and 01 autos only, I think........the outlet elbow on the back of a HX35 and HY35 are 3"...........The HX40 is only offered with a 4" outlet.......You do not need any adaptors to run an aftermarket 4" downpipe on your HX35 - they bolt right on.
Old Mar 9, 2005 | 06:48 AM
RowJ's Avatar
CTD NUT - FYI...HY35 was on 2002 also.
mkrenn - As CTD NUT says, if you order an aftermarket 4" system, and specify it's for an HX-35, the downpipe comes necked down in the top 4" to hook right onto your turbo.
RJ
Old Mar 9, 2005 | 06:26 PM
mkrenn's Avatar
Thanks all. Cool info. I made an uneducated guess on my turbo.
Point being, I would line a 4 inch oulet on the turbo. Sabby anyone?
That way when I bolt a 4 inch downpipe on, its 4 inch to 4 inch. NOT 3 to 4 or 3 1/2 to 4. I'm thinking this would greatly reduce EGT's.
I thought I seen this somewhere.
Anyone?
Old Mar 9, 2005 | 07:13 PM
MasseyMan1089's Avatar
I have a 4" downpipe for sale!! Check out my classifieds!
mattmanj2001
Dec 11, 2010 07:33 AM
Jordan5687
Feb 14, 2007 05:00 PM
SSminnow
Jan 13, 2007 09:10 AM
kutch
Jan 8, 2007 11:38 AM
Haulin_in_Dixie
Apr 13, 2005 06:33 PM
