Donaldson BHAF
Old Nov 9, 2004 | 04:12 PM
GSP's Avatar
GSP
Donaldson BHAF
Anyone have a Donaldson BHAF?
Thats all I can find local around here for $52.85
Is the donaldson a 4" connect and is it a hard plastic , just clamp on, Is it a good filter?
Rick
Old Nov 9, 2004 | 04:28 PM
I have one. Price sounds average. The plastic isn't real hard, but it's not floppy, either. It was designed to clamp over a pipe, not to have a hose clamped over it, so a short stub of pipe to reinforce the flange is a good idea. PVC works fine for this.
Old Nov 9, 2004 | 04:39 PM
apache's Avatar
Ive used several from Napa with no problems.
Old Nov 9, 2004 | 05:00 PM
GSP's Avatar
GSP
Dont the Napa ones have a 3" connect? I dont want that....
Old Nov 9, 2004 | 07:42 PM
matthopp's Avatar
My Napa BHAF works great!! No mods needed
Old Nov 9, 2004 | 08:16 PM
d0dg301's Avatar
I just picked up my NAPA filter today. MAN that thing is BIG! I curently use a K&N FIPK filter but noticed alot of oil around my silencer ring and inlet for the turbo. Didn't like all the oily fill over everything so I left my silencer ring off and bought a napa filter.
I think that my heat shield that came with the K&N filter will still work, I will find out tomorrow. Just need to order up an outerware for it now.
Old Nov 9, 2004 | 08:43 PM
coiler33's Avatar
d0dg301 let me know if it works for you I was thinking of doing the same.
Old Nov 9, 2004 | 09:24 PM
DPG's Avatar
DPG
My NAPA BHAF (part# 2790) had a 3" inlet neck. I switched to Baldwin, was less expensive, and has the 4" inlet neck, so no adaptor needed.
Old Nov 9, 2004 | 09:35 PM
GSP's Avatar
GSP
So whats the deal ? Some napas ship a 3" and some a 4" .
The napa here says they can get one for $54.
Do You other guys have 4" necks? ? ?
DOdg301 ,, I have a little oil film too in my turbo from a K&N
Old Nov 9, 2004 | 10:00 PM
d0dg301's Avatar
I just went out and measured my filter and the new napa 2790 has a 4 I.D. measurement. I should be good to go
Old Nov 9, 2004 | 10:15 PM
GSP's Avatar
GSP
Hey Dodg301...
Is your Napa 2790 a harder rubber/plastic that will hold up to the clamp ?
Hell,,, I will just go down to napa and get one if its the hot ticket...
Old Nov 9, 2004 | 10:20 PM
dieselminded's Avatar
Ive NEVER seen a 2790 with a 3 inch inlet you'd think they'd all be the same.
I think all these are the same but some are marine.
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
DONALDSON ECB105006
Old Nov 9, 2004 | 10:50 PM
d0dg301's Avatar
Yes the plastic part of it seems to be very hard. Both the solid end and the end with the opening. pretty stout feeling.
Old Nov 10, 2004 | 03:26 PM
HOHN's Avatar
Ditto. My NAPA 2790 is 4"-- the stock inlet tube connected right up.
Of course, you have to subtract the flange thickness of the BHAF to get the I.D., so maybe it's less than 4" in true I.D.
JLH
Rickcher
Sep 2, 2009 05:08 PM
Ace
Oct 31, 2007 06:46 PM
Mixer Man
Sep 17, 2004 08:14 PM
