Comp + Jammer 3 Injectors = ?
Old Oct 6, 2005 | 12:24 PM
CTD_Neil's Avatar
my comp showed up today...its killing me sitting there in the box. im dying to put it on and test it!
"Don't just stand there, install it!!!!!"
Old Oct 6, 2005 | 12:42 PM
RowJ's Avatar
Originally Posted by Jetpilot
A typical setup I use for 500 HP is a B-1 turbo, drag comp, and Mach 4 injectors (150 HP). This setup yield and honest 500-515 HP.
Doug
Just me, but I would never run a full B-1, if that is what you meant, on a street truck with an automatic. Even a B-1-2 will get toasty with a drag comp & Mach 4's...but at least it will be a drivable compromise (on the street).
RJ
Old Oct 6, 2005 | 12:51 PM
getblown5.9's Avatar
I AM AT WORK TIL 4
Old Oct 6, 2005 | 01:54 PM
CTD_Neil's Avatar
D-amn work is always getting in the way of the important things.
Old Oct 6, 2005 | 02:11 PM
i know man...plus i have to get to fed-ex tongiht to ship out my van aaken that i sold to HOHN. hope he enjoys as much as i have, i got the bug tho and needed more fuel
Old Oct 6, 2005 | 03:49 PM
HOHN's Avatar
Originally Posted by mstordahl
Interesting...I was quoted by DTT that my truck with JUST the Comp and Jammer 3 injectors would put out at least 900tq with my stock turbo. Guess that is not correct then.
Thanks for the replys guys.
Matt
I've dynoed over 900lb-ft on two different dynos on two different days with just an EZ and dd2s. I can't see why a Comp and J3s would fall shy of 900 lb-ft.
You should have plenty for 900lb-ft. But EGT will be quite warm.
Old Oct 6, 2005 | 04:37 PM
BigBlue's Avatar
My roommate dynoed 899tq with a drag comp, mach 1.5's, and stock HX35.
Old Oct 6, 2005 | 05:38 PM
its on...
dd3's, comp slightly modified hx-35 and it will scream right to 1400, then slowly climbs to 1450, i didnt go any higher tho it would have. 5x5 smokes so bad its not even controllable by foot, i have it on 4x1 and it seems to pull hard, smoke less and not heat up as quickly.
once the newness wears off tonight i will keep it on 3x2 or so and leave it there. i need to come up with a clever way to mount it tho, i bought it used and had no velcro so for now its taped right to my CB...it works...but is hard to reach to change the level
xOmertAx
20
Feb 17, 2007 09:52 PM
OHFarmboy
Dec 3, 2006 07:16 PM
blueandsilver02
Sep 27, 2006 03:14 PM
Ramirezh
Mar 22, 2006 07:55 AM
kwhite4
Feb 2, 2005 09:06 AM
