Clutch, is it stock?
Old Apr 10, 2008 | 02:51 PM
PaulDaisy's Avatar
I ran into another question with my truck. I bought it used, and of course have no info on what was done to it. But today I drove a friend's truck, a 2001 3/4 ton long bed, and his clutch pedal is a lot softer than mine; it releases in the lower 1/3 of travel and feels the same pressure all the way through. My pedal feels stiffer at the upper 1/3 of travel, then kind of "lets go", becomes lighter, and releases in the upper 1/3 of travel. Do I have a non-stock clutch, or it is just an individual difference?
When I was working under the truck, I think there is evidence there that the gearbox and bellhousing were removed in the past.
-P
Old Apr 10, 2008 | 03:24 PM
HOHN's Avatar
I'd suspect an aftermarket clutch. My Con FE changed the feel in almost the manner described. The pressure is less linear, with light pressure at the top and a lot more needed to keep it at the floor.
It's part of the leverage setup to increase pressure plate load to help holding power.
jmo
Old Apr 10, 2008 | 06:14 PM
Big Dblue's Avatar
Is it hard to get it into gear? Or does it want to hop off the line in 1st?
CentralTXDodge
Mar 3, 2009 09:15 PM
D45
Aug 11, 2008 12:26 AM
jgiachino
May 12, 2008 02:06 AM
cumminsdriver635
Aug 8, 2005 05:46 PM
sammy340
Apr 5, 2005 03:55 PM
