Can you feel the diff betwwen hrvp and so ??
Old Mar 18, 2007 | 07:17 PM
jr22's Avatar
Hello, i just installed a shovp44 from industrial injection and a fass 150/150 system after my 1st test drive i really didnt feel any differance so, i had my wife drive it and she said it has more power till it shifts {auto} but then feels the same. on a stock truck with a auto are you going to feel any other differance ?? Thanks, jr
Old Mar 18, 2007 | 09:55 PM
francis212's Avatar
Are you running any different injectors or a comp box of any kind? If not i think thats where you will maybe feel the biggest difference after adding that pump.
Old Mar 18, 2007 | 10:32 PM
Ph4tty's Avatar
Maybe the auto is losing the power it making. Best I can figure my shovp44 was worth 80 hp with my setup.
Old Mar 19, 2007 | 07:41 AM
RickCJ's Avatar
It'll add a lot more more fuel! but without a boost fooler you still will only see 20 lbs. Get a boost fooler and hang on! You should notice a big differance up to 20 lbs.
Are you sure you got the SHO? they cost around $1800!
Old Mar 19, 2007 | 08:29 PM
jr22's Avatar
I called and talked to II today relayed the part number to them and they said yes it was the shovp for there automatic trans. The only thing that that i have done is what listed in my sig so no chip or injectors. They said i should be able to feel the differance and not quite sure why i cant ?? they did offer to send me a another one to exchange for the one currently on the truck ?? Thanks, Jr
Old Mar 19, 2007 | 11:08 PM
24vCTD's Avatar
Just last month I installed the II SHOVP44/FASS setup on my truck (although mine is a 5-speed and I opted for the 95 gph FASS.) From a dead stop it seems the same as before (maybe only because I don't take off hard with it), but once I get it rolling it flat out runs like a scalded cat. On the highway, doesn't matter if I start out at 55 mph or 70 mph, If I wanna pass somebody I can do it easily because there is so much more top end power than before. One thing you might try is resetting your APPS (look it up in the tech facts section.) That has been known to improve throttle response. I don't know personally; I still have yet to do that to mine.
Old Mar 19, 2007 | 11:38 PM
1-5-3-6-2-4's Avatar
I felt a huge difference, from my rotted SO to the II HRVP. All else stayed the same.
Old Mar 20, 2007 | 12:42 AM
Ph4tty's Avatar
Do a search for turnbuckle and j-hook so you can get more boost out of that hy turbo. BTW if you had guages you'd see boost and pyro temps and you'd *know* if theres a difference =P
Old Mar 20, 2007 | 12:46 AM
PourinDiesel's Avatar
The hot rod pumps add bottom end fueling while giving you the fuel up top that a standard output truck would have already.
If you already have big injectors and a box you will feel less than if you were a truck closer to stock when adding the HRVP44.
Old Mar 20, 2007 | 08:22 AM
Jetpilot's Avatar
Your truck is probably defueling, thus the lack of extra power.... At a minimum add a boost fooler or better yet add a mild box like an Edge EZ.
Doug
Old Mar 20, 2007 | 08:18 PM
jr22's Avatar
I talked to a shop closer to the city and they said that he has had similar phone calls concerning the II shovp ?? His suggestion was to add a box to the truck to get the full power of the new pump.
whiteVLX
18
Aug 14, 2006 11:04 AM
Ph4tty
15
Jan 26, 2006 07:25 PM
jefe4x4
Jan 24, 2006 07:47 AM
jet
Nov 17, 2002 08:23 AM
