Boost and Smarty.
Boost and Smarty.
I have had a Smarty on my Cummins for a couple of weeks now, and the boost maxes out at 20 psi. What, if any, benefits would I see if I added a manual boost controller or elbow? Thanks
What are you seeing for EGT's on a WOT run in top gear? If you don't have enough fuel (stock) then you don't really need more boost. If you are getting hot then a manual boost controller or boost elbow will allow more boost and help cool things off.
Lower EGTs. Smarty increases fueling enough to where you'd benefit from more boost, up to 30psi or so.
It will also feel a little peppier with the WG staying closed longer.
stock03
34
Apr 21, 2011 07:40 AM
vwjunkie53
19
Nov 9, 2007 02:27 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
