Boost "problem"
Old May 22, 2008 | 10:53 PM
bootsdodgejn's Avatar
Boost "problem"
Well once i got my gauges for my truck.(truck still being stock) I was reading 21psi.Then once i got the smarty i was told the my boost would go up.Well is stayed around 22 psi.I was also told that if i got a box the boost will go up.Well i just put the adrenaline in and well guess what im still at 22 psi.Is this normal or am i on somthin.
P.S. My next door neighbor has same year truck,same everything except the he has a edge juice with attitude and he is gettin 40 some psi..
So any ideas.
Old May 22, 2008 | 11:05 PM
sal3c's Avatar
same thing is happening to me. i installed the adrenaline and gauges at the same time so i dont know what my truck was without it but on PL10 on the production tunes i only made bout 22psi
Old May 22, 2008 | 11:06 PM
Beast2B's Avatar
you have to mechanically hold the wastegate closed as well as electronically fool the ECM. Auto trucks need a J hook or spring or turnbuckle while manual trucks need a boost elbow.
Old May 23, 2008 | 12:12 AM
thing is like i said the neighbor has same truck no jhook same turbo,just has a juice with attitude.
Old May 23, 2008 | 02:00 AM
IntakeRacing's Avatar
maybe it was already done and he jsut didn't know. possible?
Old May 23, 2008 | 08:55 AM
Beast2B's Avatar
if his is hitting 40 psi, then his wastegate is disabled somehow or stuck closed.
Old May 23, 2008 | 09:08 AM
Ill have to check to make sure.Im goin to put a hook on mine.But the truck accelerates like a bat out of hel! without the extra boost
Old May 24, 2008 | 12:55 AM
Lightbulb
Well um yea found out that his truck is a 02 not an 01.
Would this make a diffrence?
P.S no jhook,and wastegate works. ON HIS
Or am i on somting
Old May 24, 2008 | 12:45 PM
vrj's Avatar
vrj
So any ideas.
Question regarding the boost level your neighboor is getting and what you're wanting.
With the truck being stock, I'm thinking that boost levels over 25psi's on a stock engine and transmission could definetely cause some major problems. Injector's could blow, transmission could break, head studs stretching, head gasket could blow, stock fuel system overworked.
I'm not trying to rain on your parade I just hate to see someone break their prized position and investment.
I plan on pushing more psi's on my truck once I get my "Super B" Kit that will give me a the 40psi's that I'm looking for, but, thats after the transmission and injectors.
Good luck with your rig!
roughstock
Nov 2, 2013 01:48 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
MedicShawn
Feb 14, 2004 09:47 PM
