Boost Gauge ?
Boost Gauge ?
I just got my boost hooked up and it seems to work great. But my question is, when i turn my E-brake on the gauge it makes a rattling noise. I think it is just the needle spring rattling, but is it normal or do i have a bad gauge. But like i said it works great when i get on it. Thanks for any info.
I wired it to the dash panel fuse. Thats where it called to wire it. But it seems to be the spring mechanism for the gauge needle thats is vibrating when i turn the exhaust brake on.
I see now, as you see i dont have a brake. but i can see maybe like a harmonic pulsation from the brake when it's applied. my stroke kinda had a harmonic type of noise from the brake on it. I adjusted it away with the adjuster on the rod. I actually opened it up a little.
A needle valve almost shut or a gauge snubber installed in the pressure line will eliminate pulsation noise on a fuel pressure gauge, I'm sure it will also work with boost. It might slow down the gauge response to an unacceptable level though.
It will only set you back $5 to experiment, give it a try.
Performance & Accessories Bully Dog Triple Dog 40500 w/Crazy Larry, Outlook, boost gauge, pillar mount, boost f
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
CRXsi
Mar 31, 2006 07:56 AM
