Boost gauge
Old Nov 17, 2002 | 09:52 AM
KC's Avatar
KC
Boost gauge
I am wondering whether to get a 0 to 30 or 0 to 60 gauge. I plan on getting some type of computer upgrade like the Edge or something similar?<br><br>KC
Old Nov 17, 2002 | 10:04 AM
KatDiesel's Avatar
Re:Boost gauge
[quote author=KC link=board=7;threadid=7151;start=0#68231 date=1037548358]<br>I am wondering whether to get a 0 to 30 or 0 to 60 gauge. I plan on getting some type of computer upgrade like the Edge or something similar?<br><br>KC <br>[/quote]<br><br>Get 0 to 60 psi and be done.<br>I've bought 3 gauges, 0 to 35psi, 0 to 50psi, and now 0 to 60psi.
Old Nov 17, 2002 | 10:20 AM
chuck3's Avatar
Re:Boost gauge
Unless your going to do some HEAVY bombing a 0 to 35 will be good enough.
Old Nov 17, 2002 | 10:28 AM
KatDiesel's Avatar
Re:Boost gauge
[quote author=CHUCK3 link=board=7;threadid=7151;start=0#68240 date=1037550059]<br> Unless your going to do some HEAVY bombing a 0 to 35 will be good enough. <br>[/quote]<br><br>Just an EZ or any mild box will peg a 35psi gauge, if the wastegate is set right. If you were staying stock or maybe just adding 275's ....I'd say the 35psi is good enough. So no HEAVY bombing needed.
Old Nov 17, 2002 | 11:29 AM
KC's Avatar
KC
Re:Boost gauge
How about with a Edge Comp box?<br><br>KC
Old Nov 17, 2002 | 11:49 AM
scottrod's Avatar
Re:Boost gauge
I gotta echo Kat.<br>Get the 0-60 and be done ;D
Old Nov 17, 2002 | 11:50 AM
KatDiesel's Avatar
Re:Boost gauge
[quote author=KC link=board=7;threadid=7151;start=0#68267 date=1037554192]
How about with a Edge Comp box?[/quote]
Definatly get the 0 to 60psi. You'll want more power later if your starting with the COMP.
Old Nov 17, 2002 | 08:28 PM
BFC's Avatar
BFC
Re:Boost gauge
I can get 42 psi out my Comp when set on kill. Go with the 0/60 and be done with it.........well at least until you put the twins on! ;D ;D ;D<br><br>Glenn
Old Nov 18, 2002 | 03:36 PM
rattle_rattle's Avatar
Re:Boost gauge
I got the 0-60 boost gauge and I'm glad I did. The WOT boost is about 32 with the Edge EZ and the boos elbow. A 0-30 would have been pegged.
Old Nov 19, 2002 | 04:19 AM
KC's Avatar
KC
Re:Boost gauge
THanks for the help!!<br><br>KC
Old Nov 21, 2002 | 02:17 PM
doug's Avatar
Re:Boost gauge
keep in mind that in order to effectively utilize more than 35 lbs, you'll need a different turbo. if you're committed to keeping an HX35, for example, boost pressures over 35 psi will give you little more than high EGTs and a 0-35 psi gauge will give you greater accuracy than a 0-60 gauge will.
Old Nov 21, 2002 | 07:13 PM
Scotty's Avatar
Top's Younger Twin
Re:Boost gauge
I use a 0-80 oil pressure gauge that says 'pressure' only on the face.
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
