Boost elbow where to find one?
Old Oct 17, 2007 | 08:38 PM
  #46
Vern Calhoun's Avatar
Alright, so what I have gathered the elbow "regulates" the pressure applied to the diafram that controls the wastegate. Now, I also have a Superchip programmer, well the old school D-Box(65hp/185tq), and I plan on making an adjustable from Ace Hardware. The question I will ask is, how must boost is safe and when should I back out the needle valve to keep the IP from starving like a poor kid in Africa? I ordered a set of gauges from DieselManor earlier today so just as long as my FP is good I plan on making an elbow. Does anyone have an "Adjustable" with the allen screw? If so, can you post us what size screw/threads and the location there-of? Thanks
Old Oct 17, 2007 | 09:52 PM
  #47
motomac3's Avatar
the way i see it... your programmer doesnt do boost fooling so your truck will probably throw codes for overboost and put your truck in limp mode... and i dont believe your boost will have anything to do with your vp. it is only throwing more air in. your programmer is what will add more fuel an it will only add so much. i have heard that the stock turbo will do 30-35psi so you really need the gauges to know how much boost you are making and how much to screw out the valve to adjust the boost.
Old Oct 17, 2007 | 10:21 PM
  #48
Found the install instructions. Go to It
Sounds like to me that the box will fool the computer and allow higher boost levels.
Bowser50
Aug 8, 2010 11:30 PM
tritont
Sep 10, 2007 08:18 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
