Boost elbow where to find one?
Old Oct 2, 2007 | 01:02 AM
  #31
motomac3's Avatar
Originally Posted by Jturs
thanks for the input well im not really to worried about over boosting cause i will only run it like half closed to be safe.
but yeah i just went out and looked my turbo and saw the stock fitting and how it all works
and since i have a superchip which will do my boost fooling i think i should be fine, anyone else have any input.
thanks
gauge will still be nice if you have boost fooling and if that superchips programmer adds more fuel. your turbo will make more psi than stock. shouldnt be enough to hurt it but i like knowing. i am ordering my comander tomorrow next day air so i should have mine all set up by this weekend. i want to see what my boost is before and after the new elbow.
Old Oct 2, 2007 | 01:29 AM
  #32
jeepin's Avatar
Jturs My boost went from 20 pounds to 30 pounds when I installed the elbow that is with it all the way closed.
Also I noticed that the boost came on sooner I will get to around 25 pounds at 1700-2000 rpms
That is with what I have in my sig.
So I dont think that you should have a problem with over boosting just my opinion.
Hope that this helps.
Old Oct 2, 2007 | 02:13 AM
  #33
wcbcruzer's Avatar
Originally Posted by motomac3
...you wont make much more than stock boost unless you add more fuel.
Yea you know what I'm talking about.
Old Oct 2, 2007 | 07:23 AM
  #34
BIGBEN's Avatar
Originally Posted by jeepin
BradN1
It is 1/4 not 3/8 and the hose is also 1/4 mine is an 02 .
I made my own, very simple. but the threads on my 00 where not 3/8 NPT or 1/4 NPT. They are 1/8NPT. I hope this saves some trips to the hardware store.
Old Oct 2, 2007 | 07:55 AM
  #35
BradN1's Avatar
Thanks BIGBEN! Unfortunately, it didn't. I first bought 3/8" then returned it for 1/4". The third trip, I bought a 1/8" to 1/4" coupler and called it good!
I did a write up on it complete with pictures and parts list, but I haven't figured out how to upload it yet.
Old Oct 2, 2007 | 07:53 PM
  #36
Jturs's Avatar
thanks for all the info guys greatly appreciated. so i just got done making my boost elbow with the needle valve, and i ran it with it open all the way which should be stock then about 1/2 way closed and felt a little difference but then at full close it kinda of felt funny and made a little weird noise but is that just cause all that boost has no where to go once i let off or cause the wastegate isnt opening at all? also kinda felt like my trans started to slip, bad news yes i know. but i decided to keep it open all the way till i get some guages and a getter tuner. any input about all this would be great.
thanks
Old Oct 2, 2007 | 08:12 PM
  #37
Jturs's Avatar
just thought of something. maybe my superchip did do the boost fooling or whatever and put my truck in limp mode.
Old Oct 3, 2007 | 12:09 AM
  #38
Jturs's Avatar
anyone have anything else to say?
Old Oct 3, 2007 | 10:08 AM
  #39
motomac3's Avatar
well if your superchips did add more fuel and it has boost fooling...it is possible that you overboosted. my truck is basically stock and i am not puuting my boost elbow on till i get my gauges first so i know what kind of boost i am making. my suggestion to you is dont run it with your valve more than half way till you get some gauges.
Old Oct 3, 2007 | 10:17 AM
  #40
Dodge359's Avatar
The store bought boost elbows also have a small hole on the elbow. This will further limit boost to the wastegate. When mine was a single I could get 42psi out of the poor little hx35.
Old Oct 3, 2007 | 02:42 PM
  #41
Jturs's Avatar
yeha thats what i was thinkin, i will probally keep it all the way open just to keep it on the safe side. does anyone know for sure if the superchips has boost fooling i cant really find much info about them, guess its not a commonly used product.
Old Oct 3, 2007 | 02:44 PM
  #42
Jturs's Avatar
wow 42psi outta the hx35 sounds like alot of hot air. but i just made mine from fitting i got at ace hardware and they are all straight through so i dont think i have to worry about that small hole your talking about.
Old Oct 3, 2007 | 04:10 PM
  #43
Dodge359's Avatar
Ya, Im sure it was damned hot air but it dynoed at 526. The hole in my boost elbow went into the atmoshere. The more you screw in the allen head the more it forced out the little port. Worked like a charm with a single but does all kinda weird stuff with twins.
Old Oct 3, 2007 | 04:32 PM
  #44
motomac3's Avatar
i have seen that qustin asked on here before, i believe the final outcome was yes it does but i am not 100% sure. you can go to superchips website and get there 800 number and call them tomorrow and tell them what you have and ask. they should be able to tell you.
Old Oct 3, 2007 | 07:11 PM
  #45
Jturs's Avatar
yeah i am plannin on calling them tomorrow to find out for sure.
but since i work at a dealership when i got off work today i scanned my truck and no codes came up so i guess i didnt over boost or put it in limp mode.
