Boost Elbow 98.5 02
Old Jun 16, 2006 | 12:39 PM
vj_M's Avatar
Boost Elbow 98.5 02
I have a Boost elbow that came with my Edge Chip. Now My question is where does it install on the turbo.? or is this only for the Standard Transmissions? Mine is an auto.
And has anone heard of a Spin wheel for the turbo On a cummins.? the 7.3L have them and they are called a Commpression wheel.
Old Jun 16, 2006 | 02:05 PM
Topper's Avatar
Look at the bottom of your turbo with your intake off. It replaces the copper elbow with the hose coming from it.
Topper
Old Jun 16, 2006 | 02:47 PM
Charlie8301's Avatar
Boost elbow wont work on a '02, you'll have to use a turn buckle or a J-Hook
Randy
Old Jun 16, 2006 | 02:56 PM
vj_M's Avatar
Does the J-Hook make much of a difference.? I do believe that that runs on a spring...? to work the wastegate.? I have a plunger like thing on a rod, if iam correct, does that replace that.? and does Bully Dog the only place that carries them.? and are they hard to install.?
thnanks
Old Jun 16, 2006 | 03:21 PM
J-hook will help with max boost, It holds the wastegate shut. Pretty easy to install
here's the link
http://www.tstproducts.com/index.asp...PROD&ProdID=63
Randy
Old Jun 16, 2006 | 03:33 PM
Sea:\>Drive's Avatar
Looks like the J-hook is spring activated. With enough fuel, how high will it hold the watedgate closed, 30, 40, too high? Just curious as I doubt my VA will get it much past 30 if that...
Old Jun 16, 2006 | 10:45 PM
vj_M's Avatar
Sea Drive,
Where did you get the Paint match for ur A-pillar....? mine is Close but not right on... that looks pitty close, closer then mine... I bought Chrsllier Tan from autometer but it came out White when it dryed. what was the name of that color.?
Old Jun 17, 2006 | 03:16 PM
ib516's Avatar
I have the J-Hook on my 02 auto. I was told it increases max boost from the stock 19-21psi to 26-28psi.
Old Jun 20, 2006 | 10:33 AM
Docismyname's Avatar
I recently placed a turnbuckle on my truck, pulling 32 pounds of boost (12 pound gain of boost) , and drooped the egt's way down
Old Jun 20, 2006 | 10:58 AM
Gotlift01's Avatar
I'm also running a turnbuckle..........made a huge difference in boost and EGTS.. Stock I couldn't get over 20psi and now I'm at about 34-35psi.........made a difference in performance too!
~Nick
Old Jun 20, 2006 | 11:02 PM
bobwhite's Avatar
Their right about the boost elbow on the 02's, it has a hard line instead of the fitting, but don't get rid of the boost elbow that came with the edge box. It can also be use on alot the the aftermarket turbos. I kept mine and used it on my HX 40. With the fuel box turned all the way up, I max out around 38-39 lbs of boost.
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
