Boost elbow
Old Aug 16, 2008 | 11:01 AM
spooled142's Avatar
Thanks but i think the turnbuckle is fine at 35 lbs of boost till i get my new turbo.
Old Aug 16, 2008 | 05:58 PM
97 D-Tec's Avatar
yea 35 should be fine i ran 40 in my stock turbo
Old Aug 16, 2008 | 07:07 PM
97 D-Tec's Avatar
Old Aug 17, 2008 | 09:23 PM
Highrlr's Avatar
So that turnbuckle just holds the wastegate closed then? So can you adjust it to the max boost that you want? Or just install it so the wastegate cant open?
Old Aug 17, 2008 | 09:31 PM
spooled142's Avatar
Yea I adjusted mine to the psi that i wanted. I guess you could lock it down so it doesn't open at all but then you will have to go easy on the skinney pedal so you don't over boost and blow your turbo or your head gasket. If you are like me I have a real lead foot so holding the wastegate closed was not an opition.
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
