Boost, EGT, Fuel pressure gauges
im looking to install a boot, egt, and fuel pressure gauge and dont even know where to begin on how to plumb these, if anyone has any printed instructions they can send me write me and and let me know i would greatly apriciate it.
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
you should fill in your signature so people know which truck you have. That we knmow which directions to give. Between the 3 generations of Dodge Cummins, installation of gauges is pretty much the same, but there are a few difference.
Boost is easiest to get a boost bolt from most online shops and it replaces one bolt from the top of the head by the injector lines.
Pyro, drill and tap the rear manifold for a pre turbo setup. Lots of worry but it's easy.
fuel press, you can either get a tapped banjo bolt and replace the stocker from the exit side of the filter housing or go directly to the shrader test port on the VP.
Some opinions but use the search for MANY others with pictures.
EGT
boost
Good luck.l
EGT
boost
Good luck.l
I got my gauges through dieselmanor.com and they came with really good instructions on how to do the install. If you think about what the gauge needs to do, it isn't too hard to figure out generally where it needs to plumb in.
And also how cridical is a fuel gauge, about the only other mod im going to do is some mild injectors, shold i be worried about the fuel pressure with everything else pretty much being stock
Yes you should watch that on this trucks, but what i did before i got around to getting the FP gauge in was at least check the pressure once in a while, you can do that right on the side of the VP with a fuel pressure tester you can get at napa or borrow one from a friend or neighbor.
good luck.
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
FastSS
20
Jul 15, 2004 12:01 PM
