Black Smoke 2 Much??
Old Sep 29, 2006 | 12:12 PM
Gman_dodge's Avatar
Question Black Smoke 2 Much??
I am a new member and owner and have recently put a superchip in my truck and have noticed that it shoots out a lot more black smoke in early rpms...do i need more air via diff type of filter or any other mod to help this or is this pretty normal? thanx
Old Sep 29, 2006 | 12:52 PM
Gotlift01's Avatar
It's normal, it just means you are adding more fuel at a lower RPM......then once the turbo spools up it clears up the black because it's burning the fuel. I wouldn't worry about it, most guys here LIVE for smoke!!
~Nick
Old Sep 29, 2006 | 01:06 PM
haloman's Avatar
I won't give an opnion on black smoke but it does look like you need some gauges (pyro,boost, etc) seeing as how you have a chip on your truck
Old Sep 29, 2006 | 02:36 PM
Diesel Dummy's Avatar
Is their any such thing as to much(black) smoke!!!
Old Sep 29, 2006 | 02:41 PM
dieselrob's Avatar
Only whens a cop pulls you over and cites you cause ya stopped rush hour traffic in the middle of a 4 lane intersection and then follows you for a 1/2 mile and you dont notice him threw the smoke. But other wise not really.
Old Sep 29, 2006 | 03:20 PM
dodgeguy71's Avatar
Wow dieselrob, that sounds to detailed to be a scenario? Your not talking from experience are you?
Old Sep 29, 2006 | 07:00 PM
RAF's Avatar
RAF
How much smoke are you getting? The reason I ask is I have the Super Chips and I have to romp on it pretty good to get some smoke thats real noticeable
Old Sep 29, 2006 | 08:05 PM
STACKED's Avatar
it sounds like you might be stacking chips. are you sure that is all you have.
Old Sep 29, 2006 | 11:16 PM
Mopar1973man's Avatar
Just remember that Black smoke is UNBURNED FUEL! So you basically blowing money out the tail pipe...
But you might check your MAP / IAT sensor connections. While your there you might check the sensor to be sure they are not all gunked up...
Old Sep 29, 2006 | 11:40 PM
Gman_dodge's Avatar
thanks alot for the feedback and its not a whole bunch and im pretty sure i dont have anything stacked up i was just wonderin cuz i know its unburned fuel and thats why i was wondering if i could save it somehow oh well im sure not complaing about the extra smoke cuz it does look cool when the car behind you drives through it...
Old Oct 1, 2006 | 07:28 AM
Stock 02's Avatar
Whats the best way to make a CTD smoke like a coal train?
Old Oct 1, 2006 | 09:49 AM
The real answer is to build it for power. The more power products you put to it the more smoke the Cummins will make.
Injectors
Chip/Power Box
Cam
Timing
Turbo(s)
Just how far do you want to go...
Old Oct 1, 2006 | 10:29 AM
RowJ's Avatar
Big injectors and a big laggy turbo. Problem is you can't control it when you want to. And if you don't want to control it in traffic .... please sell your truck and buy a 'coal train' , cause you run the risk of ruining it for the rest of us!
JMO - RJ
bradshaw106
May 3, 2009 08:39 PM
P R N D 2 1
14
Dec 5, 2006 06:45 PM
BlackSheep5
Nov 27, 2006 07:52 PM
bensdad_canada
May 9, 2005 10:56 PM
dhe9
Nov 14, 2003 07:31 AM
