Bigger turbo same boost?
Old Sep 3, 2003 | 10:55 AM
gunracer1's Avatar
Re:Bigger turbo same boost?
not always, do the pump mod an tell me what a differance you get. then save up 400 buck for some injectors. when i turned my diaphram in my last 92, it would out run my friends 99 5 speed truck to 90.
Old Sep 3, 2003 | 11:05 AM
ramguy's Avatar
gunracer1;
I did the diaphram adjustment last night and lots of smoke no more power and boost was the same 20psi. :'( I may have one of the engines w/ inectors that won't respond to the pump dial up, that I read about on the dodge ram.org :-.
ramguy
Old Sep 3, 2003 | 11:08 AM
gunracer1's Avatar
sound like you need the injectors, it really woke up my 92. the off the line differance was impressive. did you move your pump timing up as far as it would go?
Old Sep 3, 2003 | 11:23 AM
ramguy's Avatar
gunracer1;
Yes I bumped up all we get of it.
ramguy
Old Sep 3, 2003 | 11:26 AM
gunracer1's Avatar
check for some intercooler leaks or leaking boots
Old Sep 3, 2003 | 11:35 AM
ramguy's Avatar
gunracer1;
10-4 that's exactly what going to do. I've checked the boots visually a couple of times. I'm going to pick up some plumbing
fittings and presure check the system.
ramguy
J Lent
60
Nov 3, 2009 09:14 PM
R & A Equipment
Feb 26, 2007 11:27 PM
jmccart
Jan 18, 2007 03:26 PM
billmac
0
Mar 20, 2006 03:03 PM
