BD XMonitor Gauge
Old Sep 13, 2004 | 06:45 PM
RTharaldson's Avatar
BD XMonitor Gauge
Any pros or cons on the BD XMonitor Gauge (trans,pyro and boost). Has anyone seen or tried the steering column mount, how much view does it block.
Old Sep 13, 2004 | 08:19 PM
duke1n's Avatar
I like mine althought wish it was LCD like the SPA units and not cheesy LED display.
Old Sep 13, 2004 | 11:34 PM
Ponci's Avatar
Have one in my rig. Love it. Works great.
Old Sep 13, 2004 | 11:42 PM
2500CTD's Avatar
Got one on order. The steering cloumn mount also. Hope it is was a good choice. I'll let ya all know.
Old Sep 17, 2004 | 03:32 AM
LRod's Avatar
Just installed mine today. Pretty easy to do. Works as described. Sometimes you can't see the numbers because of the sun, but gives you the info you want.
Old Sep 27, 2004 | 07:49 AM
2500CTD's Avatar
On installing the pyro, Did anyone use the bushing? Or just tap the manifold?
Old Sep 27, 2004 | 08:50 AM
J BODY's Avatar
The weld on bung is more suited for the ford install. The first time I installed the pyro I just drilled and tapped the down pipe right behind the turbo. I then later drilled and tapped the exhaust manifold and moved the probe there. I like my X monitor.
Old Sep 28, 2004 | 07:44 AM
2500CTD's Avatar
Ok so is the fitting a 1/8 NPT or 1/4 npt. Those NPTs always mess me up being how they aren't "normal" in size. Also where do you get a NPT tap? I only have the normal style.
davelinde
Feb 24, 2004 09:22 AM
davelinde
27
Dec 28, 2003 12:55 PM
davelinde
Dec 16, 2003 02:40 PM
Goldenbear
16
Sep 5, 2003 08:59 AM
