Xmonitor install
Old Feb 20, 2004 | 03:27 PM
davelinde's Avatar
Xmonitor install
... One more question on an X-monitor install:
Where did you put the control box that goes under the dash, and how did you attach it? I was thinking about just sticking it on the firewall with velcro and wasn't sure if there was a better idea. The instructions don't say.
Old Feb 20, 2004 | 05:17 PM
RankRam's Avatar
I used Velcro on mine, it's still up there. No problems at all.
I have some pics of the install too.
Old Feb 21, 2004 | 01:55 AM
Grunt's Avatar
I used velcro (cleaned mounting surface with alcohol first) and also put a couple wire ties around it as insurance. Mounted under the dash on the dash framework.
Old Feb 21, 2004 | 11:02 AM
AK RAM's Avatar
I zipp-tied mine to a wire bundle under the dash.
Old Feb 23, 2004 | 06:27 PM
davelinde's Avatar
Hopefully the last how'd YOU do it question until I actually start this next Saturday.
Where did you take a switched 12V power source?
Tap a fuse? (which one)
Grab a line from under the dash? (which one)
thanx.
Old Feb 23, 2004 | 07:30 PM
dodgedude361's Avatar
are you guys using the Aftermarket tranny pan with the spot for the sensor?, or did you drill the stock pan?, or did you get the temp from the tranny line?, or some other way?
Old Feb 23, 2004 | 07:47 PM
davelinde's Avatar
tranny temp is by "choice c - some other way"
The Xmonitor taps the existing temp sensor and uses that voltage to determine a temp and provide the digital display. Beats me why DC just provides the idiot light.
Old Feb 23, 2004 | 08:12 PM
RankRam's Avatar
thanx.
I spent 45 minutes looking for switched 12 volts, I then pulled the center dash cover around the radio and tapped into the cig lighter.
It's easy to do, just unscrew the screw from the trashbag hook and pull the cover off and you will see the wire to tap.
Hope this makes sense I'm in a hurry.
Old Feb 24, 2004 | 09:22 AM
Grunt's Avatar
I opted for the sending remote sending unit as I ordered a Hy-Tech Double Deep Transmission pan which is already tapped. The only problems with this route is the extra $50 cost plus the fact the remote sending unit is 14" NPT and the pan is tapped for 1/8" NPT. I ended up ordering the correct unit from ISSPRO as BD doesn't even stck them. If I had it to do over I'd still use the
HY-Tech pan but opt for the standard temp unit that uses the DC sending unit. Save the hassle of finding the right size unit plus save $50 to boot.
Can't remember where I tapped in for 12v but am thinking it was the cigarette lighter.
Skip
davelinde
27
Dec 28, 2003 12:55 PM
davelinde
Dec 16, 2003 02:40 PM
Goldenbear
16
Sep 5, 2003 08:59 AM
