Banks Twin Ram Intake Alternatives?
Old Oct 10, 2007 | 03:12 PM
kevellis32's Avatar
Well I guess my real question is...Does the twin ram intake make much of a difference for anyone who has it. And if it does, is there any other company that makes a cheaper alternative to this set up. Spending 600$ on something like that seems a bit extreme if you ask me. But that is banks.
Old Oct 10, 2007 | 05:42 PM
BC847's Avatar
1st Generation Admin
Doing a simple search of these forums presents with the following ~ https://www.dieseltruckresource.com/...archid=1585686
NOTE ~ You'll find there are a lot of folks bashing the product based on NO first-hand knowledge or what "A Friend said". Pretty-much useless info.
They are overpriced for what it is. However, it is well made and does offer improved EGT control. It in itself, makes no power. . . . . . It's a y shaped piece of pipe folks.
I run one and find it well worth while in my application.
Old Oct 10, 2007 | 11:08 PM
ratsun's Avatar
BC847
I know you have one and like it and I don't want to start a argument but can you please tell me how it can help control EGTs? The stock CAC on my truck has much smaller and more restrictive inlet and outlet openings than the air-horn looks to have? I could see in 600+ hp engines with the rest of the charge air system upgraded the stock horn starting to impede the flow but with the rest of the stock system I don't understand it to help?
Can you clue me in?
Old Oct 10, 2007 | 11:22 PM
Box5's Avatar
I have one, and must say it looks good on there. But looking at ur sig, spend the 600 somewhere else like saving for a bigger turbo. I think u can get a bigger turbo for 600 like the dodgezilla right? It's a nice looking unit, and prolly helps distribute the air better, but 600 would make u alot happier spent in another way than basically a cosmetic item when it comes to performence IMO.
Old Oct 11, 2007 | 10:59 AM
JIT's Avatar
JIT
I agree with this!
Old Oct 11, 2007 | 07:28 PM
Why_Try's Avatar
Why aren't there more home made setups. Its a relatively simple design on a 12v, and even easier on a 24v. Maybe I'm missing something in the complexity or functionality?
Old Oct 11, 2007 | 11:40 PM
displacedtexan's Avatar
One member said it evened out his temps from front 3 to back 3 where there was a 150* difference before... Don't remember who though. Not even positive I read it on here.
I'm guessing that it is an issue with time to fab it up for a small gain.
Old Oct 12, 2007 | 12:04 AM
Big Blue24's Avatar
How is it even easier on a 24v? Last time I looked at my 24v, there was about 6 fuel lines clamped in various places directly over the top of the intake manifold. This is why the banks twin air is only available for pre 98.5 trucks.
Old Oct 12, 2007 | 12:32 AM
Muddin_dude06's Avatar
I am going to make my own out of either 3" or 3.5" mandrel bent pipe with no heaters in it either. Joe Hellmann makes something like this out of aluminum and sells it for like $465 I think, looks real good but $65 worth of pipe and some elbow grease will be much better on my wallet! lol.
Old Oct 12, 2007 | 01:16 AM
wcbcruzer's Avatar
Funny I was just thinking I'd like to get a twin ram. No way I'd pay $600 for it though. I believe it does help even out temps in all cylinders. Someone's gotta come out with a generic one for way cheaper.
Old Oct 12, 2007 | 05:05 AM
jeepin's Avatar
Has anyone used the ATS intake looks like you can get one for under $400?
Old Oct 12, 2007 | 08:52 AM
signature600's Avatar
I'll be building my own as soon as I can afford a TIG welder...It will be designed for looks, some performance, and easy of removal.
Chris
Old Oct 12, 2007 | 11:31 AM
MikeR's Avatar
Spend your $600 dollars on other more important things first. If you really want one then do it last, as it does not make anymore power. And when we tested it we only saw ~40 degree difference across the egt's coming out of all 6 cylinders.
Yes I do have one too. Only bought it because it looks cool...well it looks cooler after I ground the Banks name off of it!
Old Oct 12, 2007 | 06:33 PM
kevellis32's Avatar
Yea I figured that was the response I would get, A new turbo Is right on the docket after a full tranny rebuild
Old Oct 12, 2007 | 06:59 PM
Dodge359's Avatar
I have one and I really like it for the look and the extra/more even flow. I see 80+ psi so I think I actually gain by having it and besides its a great place to mount the 2nd water/meth nozzle.
