Auto to Manual Swap??
Old Jul 19, 2007 | 11:15 PM
Black04Ram's Avatar
A friend has a 99 Auto and has blowed the auto tranny up twice in a row now and is wanting to convert his truck to a six speed, and he has a line on a 06 truck with the g56, Can a G56 be put behind his 99 and what parts will be needed to do the complete swap if so?? Thanks for any advice, btw its also a 4x4..
Old Jul 20, 2007 | 09:10 AM
Black04Ram's Avatar
bump, any one have a clue??
Old Jul 20, 2007 | 09:32 AM
Gotlift01's Avatar
If I remember right, I don't think the tranny will bolt directly up to his motor being a 6 speed. I'm not 100% positive, but I think the HO's had a different bolt pattern on them for the 6 speed trannies, or atleast I think they do!
~Nick
Old Jul 20, 2007 | 10:07 AM
gmctd's Avatar
Tell'im to hit the local boneyards, do an eyewitness comparison - or can call Dodge or some of the transmission vendors to see if the adaptor ring is same, all years - get the complete trans\adaptor case setup to get the big NV271 unit
Old Jul 20, 2007 | 01:55 PM
Black04Ram's Avatar
Well he has an wrecked available 06 with the g56 and can get anything off of it.. i know u can put a nv5600 behind it but can you put this g56?? Any help appreciated
Old Jul 20, 2007 | 02:03 PM
getblown5.9's Avatar
bellhousing pattern should be the same but i dunno about anything else.
Old Jul 20, 2007 | 04:32 PM
gmctd's Avatar
Call Dodge parts, see if the adaptor is the same - see if the flywheel hub pattern is the same - the bellhousing will then fit his adaptor, and the required 13" clutch and flywheel will fit - he'll need to figger out something to do on the rear crossmember if he doesn't have the 13" wide version, and he'll need the clutch pedal stuff from the '98-'02 series, and the driveshaft\yoke
ezdemon72
14
Jul 29, 2005 10:05 AM
CGA03
Jan 8, 2005 09:42 AM
scottmn1
Jun 9, 2004 05:22 PM
Graeme
Oct 21, 2003 01:00 PM
