Ats Tranny Problems
Old Dec 17, 2006 | 10:36 PM
smkn97s's Avatar
Angry Ats Tranny Problems
I have a 97 dodge with ats tranny. While driving through town going through stop lights it takes off in 2nd gear insead of dropping to 1st. If i turn the truck off and then back on again it will take off in first for a couple times then goes back to taking off in 2nd again???????
Old Dec 17, 2006 | 10:41 PM
chadwick's Avatar
there are who sensors in the tranny, take the pan off you will see them, they are the culprit usually for 2nd gear take off. someone will chime in with the sensor names. i had to replace them on my truck the hardest part was pulling the pan off
Old Dec 17, 2006 | 11:00 PM
n0ne's Avatar
did you try calling ATS.. if its not over 3 yrs or 150k miles.. its still warrantied.. give them a call, and i'm sure they can help you..
Old Dec 18, 2006 | 09:22 AM
Gotlift01's Avatar
Mine will do that occasionally if the truck is cold so I have to pull it down into first manually and then it's fine once it warms up. I've never really checked into why that happens but those sensors would be the first place I'd look.
~Nick
Old Dec 18, 2006 | 01:05 PM
timbeaux38's Avatar
Governor pressure solenoid.
They cost about 200 bucks, and you should have gotten a new one when the tranny was built. When one goes out, it is often times a precursor to bigger problems.
Old Dec 18, 2006 | 01:28 PM
BigBlue's Avatar
Dunno bout that. I had a governor pressure solenoid go out on my stock trans at 20k miles and it was replaced and I put 118k abusive miles (about 20k of those were over 450hp with another 60k over 350hp) on it with no issues.
Old Dec 18, 2006 | 01:57 PM
timbeaux38's Avatar
I didnt say every time, just often times. Mine took a crap shortly before the tranny puked. They can be taken out as a result of crap (clutch material, ect) in the fluid.
Old Dec 18, 2006 | 02:23 PM
Mcmopar's Avatar
It sounds relatively easy, give Clint a call and they should be able to fix you right up.
Old Dec 18, 2006 | 09:37 PM
smkn97s's Avatar
Thanks for all of the help ill check into the sensors
DJ Turbo.
Oct 13, 2011 09:11 PM
maddog madden
Oct 3, 2006 10:57 PM
ramguy
31
May 13, 2003 09:34 AM
13
Apr 9, 2003 07:48 PM
j
Mar 28, 2003 06:39 AM
