Arenaline Problems
Old Jun 24, 2008 | 11:04 PM
beefmandodge's Avatar
Arenaline Problems
After installing the adrenaline, my check engine light came on and it is surging. It through a
P0237, over boost code. I cleared the code, but the code will not go away. Does anyone have any ideas?
99 Dodge Ram 2500
Old Jun 24, 2008 | 11:06 PM
busta's Avatar
have you tried updating the adrenaline?
Old Jun 24, 2008 | 11:07 PM
busta's Avatar
if you haven`t updated it you will have the stock settings which had some surging
Old Jun 25, 2008 | 12:09 AM
qzilla's Avatar
If you are getting the 0237 code then the MAP sensor is not connected properly somewhere.
Check the 3 pin connector at the MAP sensor adapter, and then also check both MAP sensor connections.
Old Jun 25, 2008 | 07:33 AM
now the truck died on the road and will not start po252 and po251 is comming up unhoked adrenaline and still no start
Old Jun 25, 2008 | 11:14 AM
qzilla's Avatar
You have something hooked up wrong.
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
