APPS High Idler
Old Oct 11, 2007 | 07:04 PM
  #256
Doj Dewd's Avatar
anybody know if subdieselmech is manufacturing these high idle modules?
Old Oct 15, 2007 | 05:37 PM
  #257
subdieselmech's Avatar
Forgotten but not dead...
Ahh yes, I did abandon this thread. I am going to do a MkII of this little device and a complete pictorial dissemination. Give me a few weeks though, it's not cold enough here to warrant jumping right into this yet....
Sean
Old Nov 13, 2007 | 05:19 AM
  #258
blk90s13's Avatar
very intresting thread and great info
Old Nov 13, 2007 | 09:38 AM
  #259
fade94's Avatar
As a side note, I have a high idle box on my 01 as well. I also have a remote start module. I was able to get the remote start aux button on the remote to kick on my high idle. Also, I mounted the box and switch behind the dash and relocated the LED and adjustment **** to my a pillar gauge pod.
Old Dec 2, 2007 | 09:10 PM
  #260
Rodram2002's Avatar
[QUOTE=Cspotrun;1290161] I suppose you could put the enclosure with the POT in the cab but your adding wire length and thus resistance to the cicuit. QUOTE]
I was thinking about putting the switch and Pot. in the cab as part of the dash. With the added wire, how much more resistance would that make? should I just put only one 1K risister in line with the Pot. to make 11K?
Old Dec 2, 2007 | 09:18 PM
  #261
bnold's Avatar
The extra resistance should be negligible..
Old Dec 2, 2007 | 09:31 PM
  #262
Rodram2002's Avatar
hmm, I'll have to give things a try and see. Now, to make sure I understand this. The more resistance, the closer you are to the APPS being at idle?
Old Dec 3, 2007 | 11:38 PM
  #263
Rodram2002's Avatar
Well, I used the idea and put the controls in my dash. I got it working, but I can only bring the engine up to 1400rpm. Not a problem really, I was just thinking it was going to have the potential to go higher. Over all, I'm happy with it.
Old Dec 4, 2007 | 12:25 AM
  #264
Doj Dewd's Avatar
rodram,
can you post pics of the install & dash control mounting?
Old Dec 4, 2007 | 12:30 AM
  #265
Scott07's Avatar
Is there any actual high idle kits you can buy with an in-cab adjustment **** rather than making one yourself?
Old Dec 4, 2007 | 01:28 AM
  #266
Rodram2002's Avatar
here is how I put it in my dash.
Old Dec 4, 2007 | 07:06 AM
  #267
fade94's Avatar
I put mine here. Mounted the box under the dash. I activate mine via my remote start remote.
Old Dec 4, 2007 | 09:20 AM
  #268
getblown5.9's Avatar
i wish i had a clue how to build one of these...i rarely drive my truck in the winter now, but i would like it more for letting the truck sit in the pits at a pull and making sure the motor is up to temp for headgasket saving purposes
Old Dec 16, 2007 | 09:43 PM
  #269
dodge00's Avatar
i just got my high idle switch installed today and i had a couple of questions. first off i started with a 10k pot like said above and it would only raise 50 rpms so i tried a 5k and it will go up to 1200rpms with the pot turned all the way to the left, but when i turn it the other way somewhere in the middle it goes to normal idle speed then if i keep turning it, it goes back up to 1000rpms. so my question is do you think this is a bad pot or do i have something wrong?
Old Feb 11, 2008 | 06:10 PM
  #270
Doj Dewd's Avatar
if i am going to run the pot and on/off switch into the cab - does that eliminate the need for the project box?
i am dumb when it comes to wiring. . . .
the rotary dial i see in some pics - is that attached to the pot?
if anyone has time to do a write up on this mod and really dumb it down (ie. APPS High Idler for Dummies!) that would help me out a lot, and i'm sure others would like it also. . . (i don't know how to read wiring diagrams, but can follow directions really well)
thanx in advance. . .
jason
