Anyone running slotted rotors?
Old Mar 17, 2005 | 09:50 AM
MDMIKE's Avatar
Its getting to be time for new front brakes on the truck and I was wondering what you guys thought of slotted brake rotors? I've already got Dodge factory pads sitting on the bench, but I was holding off on the rotors until I got some opinions. Do they really disapate the heat better, or is it just a gimmick (sp)? I'd be willing to spend the extra $$ if I know it would be worth it in the long run. I guess my only other option would be dealer rotors. I don't trust "off the shelf" rotors after my last experience with my old gasser 3/4 ton Dodge. If you do indeed recomend slotted rotors, where would be the best place to buy from? Any sponsers/vendors out there selling them? Thanks for your opinions!
MIke
Old Mar 17, 2005 | 10:13 AM
BoostdCTD's Avatar
I don't think the gassing out issue is a very big one, I believe by having slotted rotors they can't be turned anymore and it also helps promote cracking under stress. If I were to spend extra money on rotors I'd probably try cyrogenic treatment, I've never tried it before but it is supposed to help make high heat and high wear parts wear slower. I'd rather put on more sets of pads (most places warranty them) than have to deal with that hub assembly to replace a rotor at my cost.
Gassing out can happen if you are going down a big mountain with a load, while going to fast but the problem is going to fast. By the rotors not gassing out it'd only cause them to get hoter and still do the same or worse damage to the bearings, calipers, and such.
Old Mar 17, 2005 | 11:28 AM
Dieseldude4x4's Avatar
My sons truck has the slotted EGR rotors. Seem to work OK.
Old Mar 17, 2005 | 12:56 PM
hotdram's Avatar
Does your son's truck outgas as bad as this guy's does ?
Click Here
~Rob
Old Mar 17, 2005 | 01:37 PM
DavidTD's Avatar
I have slotted and cross drilled rotors on my truck. Honestly, haven't really felt a difference. But they can be turned.
Old Mar 17, 2005 | 11:03 PM
mikelr's Avatar
Just read an article where a big time racing team did some extensive testing on "cryo'd" brake rotors. They ran a set of standard rotors for a specific # of laps, pitted the car and changed over to the cryo'd set, proceeded to run the same # of laps on them. Then took both sets of rotors to a metalergy lab for analysis of the iron on a molecular level. Tests showed no evidence of the cryo'd rotors holding up any better than the non-cryoed rotors.
I'm not saying that cryogeniclly treated metals don't have benifets, maybe just not as brake rotors.
The race team I guess was very pleased with the results of the test, it meant that they were going to save a lot of money on brake rotors
As far as slotted rotors, unless your diving a race car... don't was your money
Old Mar 17, 2005 | 11:56 PM
WildBill's Avatar
Slotted rotors are good, cross-drilled is not recommended on trucks because they crack from the holes. Usally helps brake effort and stopping to put on carbon metallic pads, they stop great, longer rotor & pad life, low dusting
Old Mar 18, 2005 | 10:59 AM
infidel's Avatar
Slotted and drilled rotors have their place on sports cars but aren't normally needed on a truck. I've tried them and have noticed no difference.
Old Mar 18, 2005 | 03:40 PM
BoostdCTD's Avatar
Originally posted by WildBill
... put on carbon metallic pads, they stop great, longer rotor & pad life, low dusting
By having a harder pad it will last longer by wearing less (less dust) but it will take its toll on the rotor though too.
Thanks Mike, I was quite skeptical about the cyro treatment results there.
Old Mar 18, 2005 | 04:09 PM
Beast2B's Avatar
I run slotted rotors on our work F350 4x4 diesel. Makes a difference towing and braking is more imediate but not grabby
Old Mar 19, 2005 | 12:12 AM
BoostdCTD's Avatar
Did you upgrade brake pads at the same time? I'd suspect that'd be pads more than rotors.
Old Mar 19, 2005 | 08:05 AM
bws's Avatar
bws
slotted/drilled rotors are harder and harder to find these days for trucks.must be a reason??
Old Mar 19, 2005 | 09:43 AM
CarlJensen's Avatar
Have slotted rotors with kevlar pads and SS lines with Motul fluid from EGR. Big difference in brake function. Don't know if it's rotors or pads that help the most.
Old Mar 20, 2005 | 08:27 AM
Swayse's Avatar
I got some EBC from tirerack.com, dimpled and sloted. Best thing since sliced bread. I use the cheap napa pads with them, works great.
Old Mar 20, 2005 | 09:51 AM
ASTAR's Avatar
I also have drilled/slotted rotors and didn't really see any difference. Also got the "high perfomance" pads from Napa.
adventuris
Nov 25, 2007 03:13 PM
ocsurf16
Nov 17, 2006 08:23 PM
Fishbait
22
Dec 6, 2005 08:34 PM
akeithbrown
Dec 28, 2004 02:26 AM
Mcmopar
May 11, 2004 09:46 PM
