Air filter question
Air filter question
a buddy of mine decided to put a BHAF on his 2002 CTD. What it actually is is a filter off of a big rig. The type that slides in the air cleaner on side of truck. It was a lot cheaper than an air box ($63), and makes the turbo sound Kick ***! My question is if this could cause any problems. It is in the open in the engine compartment. It basically replaced the stock air box. The Intake hose runs from the filter to the turbo. Do you think it is a safe-enough set up for me to run for a while?
I have the same thing and you are fine to run it like that. After awhile I made a heat shield for it to keep it from sucking in the hot air off of the turbo. It was only like $10 to make. It was made out of a piece of flat tin
Here's a link to making a shield, should help keep the air filter from melting from the heat from the turbo
https://www.dieseltruckresource.com/...n&onlynewfaq=1
post # 7 lists the part numbers
https://www.dieseltruckresource.com/...f+part+numbers
I searched "bhaf part numbers" and got 92posts
https://www.dieseltruckresource.com/...archid=2956325
What are the part numbers for the BHAF?
Answer: Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Outerwear cover wr3325-105
All the info you need is in the Tech section.
here is a pic of mine, i now have the S&B.
I made my heat shield out of 1/8" stainless.
Here's the S&B, it made my turbo twice as loud.
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
EverydayDiesel
22
Jun 3, 2010 12:10 AM
Wildhog
13
Aug 4, 2008 08:07 PM
nfsommer
Apr 16, 2007 09:21 PM
