Air dog
Air dog
I'm real close to buying the Air Dog lift pump im just nervous about getting it and not being able to put it in. if i buy the pump from the DTR sight will it come with everything i need to hook it up, if not what else do i need?
yep comes with everything. the only things i have added are thread sealant,hose clamps for each fitting, and some extra large heater hose to cover the fuel line to prevent rubbing through. it is a 2-3 hour job. hardest part for me was getting the factory quick disconnect off the tank
I used a zip tie to lasso the ears that you squeeze on the disconnect and worked well
Also if you want to read fuel pressure at the IP ask for the pre tapped fitting for a couple $s extra
o yea you can call pureflow and ask them about reading fuel pressure at the injection pump (VP44) they will know exactly what you are talking about. costs like 8 bucks and had it in 5 days
trailinone
16
06-19-2009 04:28 PM
