AFC diaphragm max pressure
Old Apr 23, 2005 | 03:48 PM
ty diesel's Avatar
Question AFC diaphragm max pressure
anyone ever had a blown AFC diaphragm and at wich #psi? should I be worried to have one with my 84psi boost? If so, what is found to solve this. thinking of a pressure regulator in the feed line, or so..
Old Apr 23, 2005 | 05:29 PM
I haven't heard of one rupturing. Mine held 50 psi once. Have you thought of running the AFC off one of the intermediate stages instead of straight off the manifold? Perhaps run it off the big turbo only, or if that doesn't give enough low boost fueling run it before the 4-71.
BTW, that is an amazing setup you have on the truck. Did you do all that fab work yourself?
Old Apr 23, 2005 | 06:46 PM
infidel's Avatar
I know of several people who have blown diaphragms out by testing with compressed air. Generally most air compressors are set at 100 psi.
Old Apr 24, 2005 | 12:14 PM
1dslram's Avatar
I have ran over 80# of boost without a problem and several trucks are over 100# on a regular basis.
Bruce
Old Apr 24, 2005 | 01:51 PM
ty diesel's Avatar
ok, so I guess I don't have to worry about it.
Old Apr 24, 2005 | 09:47 PM
DZLPWR's Avatar
ty diesel, what the heck kind of motor are you running?? And boost numbers? Whats the scoop on your set-up?
Old Apr 25, 2005 | 07:10 AM
ty diesel's Avatar
it is a VM-motori hr692ht 6cyl, 3,6liter engine, twinturbo'd, supercharged(now rebuilded),
propane-nitrous and water/meth. injected. VM is owned by DetroitDiesel.
boost is 84psi. engine has 6 aluminum cylinderheads and it revvs high with it's short stroke
of 90mm.
Old Apr 25, 2005 | 07:27 AM
Dr. Evil's Avatar
of 90mm.
Well, You win the exotic engine award.....mines just a Cummins
Old Apr 25, 2005 | 05:00 PM
DZLPWR's Avatar
Wow, thats different. Pretty neat 4-stroke?
Old Apr 26, 2005 | 02:02 AM
ty diesel's Avatar
yeah, it is a 4-stroke engine. mine comes from a lamborghini LM003, but they
use them in boats and snowvehicles and streetsweeptrucks too.
it's an industrial engine.
TNfarmboy
0
Aug 20, 2006 03:02 PM
PeytonMaterne
Dec 26, 2005 01:21 PM
Jim Lane
Oct 15, 2005 08:36 AM
royta
Feb 15, 2005 10:15 PM
DJ
May 22, 2004 02:25 AM
