Advantages of ATS exh. manifold?
Old Apr 25, 2003 | 12:26 PM
Timinva's Avatar
DTR Advertiser
Looking into buying a 3 piece exh. manifold and wondering if there any real advantages to it other than not shrinking. Are the egts the same or spoolup quicker? I know these are the manufactors claims, but wondering if you are seeing it in real driving conditions. Thanks Tim
Old Apr 25, 2003 | 12:55 PM
PourinDiesel's Avatar
Re:Advantages of ATS exh. maanifold?
Spoolup with a bigger turbine housing is a little quicker.<br>I have it cause it looks cool! <br><br>If you buy one, post and I'll give you some time saving hints for installation.<br><br>--Justin
Old Apr 25, 2003 | 12:57 PM
StakeMan's Avatar
Does tha ATS manifold flow more than the stock one?<br><br>I'm still running the OEM unit. I haven't melted it yet.
Old Apr 25, 2003 | 01:48 PM
Timinva's Avatar
DTR Advertiser
Justin, what kind of tips do you have for me? I just ordered one from piers as well as the steering bearing and bracket kit. Piers really does have good customer service. Tim
Old Apr 25, 2003 | 02:37 PM
Idaho CTD's Avatar
[quote author=StakeMan link=board=7;threadid=14018;start=0#131880 date=1051293460]
[/quote]
From what I've heard it flows about 13% better than stock.
Old Apr 25, 2003 | 05:25 PM
Diesel Freak's Avatar
[quote author=Idaho CTD link=board=7;threadid=14018;start=0#131911 date=1051299470]
[/quote]
[/quote]
not if you have a stock turbo and turbine housing.
;D
Old Apr 25, 2003 | 09:42 PM
Tips for installation.
These manifolds can be a real b---- to install or they can be somewhat cooperative.
1. Have an extra set of hands around.
2. Match the existing manifold bolt holes with the new manifold.
3. Make sure the new manifold is true, if not bang rap it on the a flat surface (like concrete floor) to straighten.
4. Just start the bolts at one end and adjust manifold as you install. By adjusting I mean taking a 6 lb beater and &quot;convincing&quot; it into position, you might use a 1/2&quot; long extension to convince the rear of the manifold to line up perfectly. (these 3 piece manifolds do not adjust with your hands, there pretty tight)
5. Take your time.
6. You might want to get an extra Allen wrench/hex key and cut about half the stock off the usable end off (to fit into the middle top two bolts)
7. Buy a socket also with this Hex key size.
8. New manifold gaskets (might as well).
9. You will need to use the existing studs from your manifold (so have channel locks to remove and reinstall)
10. Anti seize is good to apply to the studs upon reinstallation.
11. Your going to have to manipulate the provided bracket to secure to your coolant lines.
--Justin
Old Apr 26, 2003 | 12:22 PM
StakeMan's Avatar
[quote author=Diesel Freak link=board=7;threadid=14018;start=0#131981 date=1051309559]<br>not if you have a stock turbo and turbine housing.<br>[/quote]<br><br>At what size does it help?
Old Apr 26, 2003 | 03:42 PM
Hmmmmmmmmmm good question.<br><br>I would guess it helps when the turbine housing cross sectional area (cm^2) has the same cross sectional area as the outlet of the ATS Manifold.<br><br>you could try a PDR40<br><br> ;D ;D ;D
Old Apr 26, 2003 | 03:58 PM
Timinva's Avatar
DTR Advertiser
Re:Advantages of ATS exh. manifold?
Dieselfreak, Do you feel it will benefit the flow to port match the ATS manifold to my PDR40 inlet? I dont even know how close they will match stock, when I get the manifold Thursday I will check and post the results. Tim
Old Apr 26, 2003 | 04:35 PM
[quote author=Timinva link=board=7;threadid=14018;start=0#132243 date=1051390690]<br>Dieselfreak, Do you feel it will benefit the flow to port match the ATS manifold to my PDR40 inlet? I dont even know how close they will match stock, when I get the manifold Thursday I will check and post the results. Tim<br>[/quote]<br><br>Personaly, I feel the only benefit to porting the ATS Manifold to match the exhaust ports, and the turbine housing is having the satisfaction of knowing that you did it.
Old Apr 26, 2003 | 04:54 PM
EricBu12's Avatar
The DC Ex. Manifold is another example of DC cutting corners to save money. <br><br>The N-14 Cummins that I drive interstate has this kind of Ex. manifold on it so yeah, junk the stocker and get the ATS You won't be sorry!<br>
TireHauler04
22
Oct 11, 2019 04:02 PM
wvopowered
Jun 14, 2008 11:49 AM
kanadiankaboy
May 14, 2008 05:13 AM
tristan21
19
May 12, 2008 12:00 AM
KwikKurt
May 4, 2003 09:32 PM
