Adrenaline ?
Old Mar 14, 2008 | 09:34 PM
fullthrottlefar's Avatar
Adrenaline ?
Hi I am new to the site and had a question about the quadzilla Adrenaline. I just purchased one and installed it tonight. How do I know If I have a good connection to the pump wire? It feels stronger than with out it but I could not tell that much differance between the levels. I can only get about 35lbs of boost and I run 60hp injectors and a Dodgezilla hybrid turbo. any help would be appreciated.
Old Mar 14, 2008 | 09:37 PM
J Lent's Avatar
I hope that you have a fuel system to support that box. I'd bet that you are running out of fuel. The stock lift pumps are junk & can't keep up with the demand of any box that taps the pump wire. What are your fuel pressure readings when this happens?
Old Mar 14, 2008 | 09:41 PM
I have a new stock lp with vulcan reloaction kit and big fuel line kit gauge shows 17psi at idle forgot to look at wot.
Old Mar 14, 2008 | 09:45 PM
J Lent's Avatar
If pressure falls below 5 psi, you will burn up the vp44 injection pump. That pump costs $1100 & they burn up really fast without fuel flow. It relys on fuel flow to cool it & lubricate it. I don't like to see pressures below 10 psi.
Old Mar 14, 2008 | 09:50 PM
I think my pressure is ok I had a tst pm3 on before this box with a vanAnken box and it pulled way harder but I had this setup out for a while and pluged the wire into the tap I had Installed for the pm3 and I think the connection may be bad How would i Know if I have a good connection?
Old Mar 14, 2008 | 09:53 PM
J Lent's Avatar
Check the connection on the pump wire. You will know when it is working correctly, lots of power.
Old Mar 14, 2008 | 11:50 PM
hink's Avatar
With the engine off and the key switch to the ON position, take a test light and probe the tap wire coming off of the Adrenaline (between ur wire tap and the Adrenaline), you should have 12v. If you do have 12v, wiggle the wire tap connector to make sure the light stays lit, just in case you have an intermittent connection.
Old Mar 15, 2008 | 01:50 PM
Ok I retapped the wire hooked it up and now the power comes on but surges at 1600-1800 I loaded the adr1018 tune and it still dose it. What now?
Old Mar 15, 2008 | 02:05 PM
hink's Avatar
Quad is working on that, but for now, that's seems to just be one of the quirks the Adrenaline has, just give it some throttle and it'll quit surgin.
Old Mar 15, 2008 | 02:18 PM
is there a different tune I should load for now to get away from the surgeing?
Old Mar 15, 2008 | 03:56 PM
hink's Avatar
Not really. I don't know about ur truck, but mine only does it every once in awhile if the conditions are right (terrrain, speed, etc.) and I just happen to be around that RPM range, usually a tap of the throttle fixes it for the moment. I just learned to drive around it.
Old Mar 15, 2008 | 06:05 PM
J Lent's Avatar
How does the Adrenaline compare to the TST power wise?
Old Mar 15, 2008 | 10:43 PM
Well my adrealine has a pretty bad surge at 1600-2000 rpm so I dont know how great it is yet. My tst and Van Aken box really moved the truck along.I guess what I like about this new one it I can controll my EGT's alot better with the limiter on it.The tst got hot real fast on top settings and alot of smoke.I have not noticed alot of smoke from the Adrealine.
bnold
2509
Jul 24, 2008 10:57 PM
qzilla
218
Jan 30, 2008 08:20 AM
sway825
Dec 14, 2007 07:57 PM
tex23455
Nov 21, 2007 04:38 AM
vzdude
Oct 17, 2007 04:32 PM
