Adjustable boost elbow settings ?
Old Jun 22, 2010 | 04:26 PM
Magnum Salvage's Avatar
Just finishing up installing the 4000GSK, 60 lb valve springs, #10 fuel plate and guages and timing bump to around 15.5 degrees. The adjustable boost elbow as well. Where should this elbow be set at ? Does adjusting the boost elbow from one point to another mess with any fueling or anything else? What I mean is if I adjust the allen screw does that require me to adjust anything else such as the idle or anything? Thank you . Cant wait to drive it and see the difference
Old Jun 22, 2010 | 05:18 PM
dodgetrucker75's Avatar
on a stock turbo, just set the boost to 35 psi or less, i would bench test it though, some boost elbows, if adjusted wrong, can actually cause the wastegate to stick open between shifts
Old Jun 22, 2010 | 07:48 PM
Tate's Avatar
Adjusting the boost elbow will only adjust wastegate opening pressures. It may increase your fueling if you get additional AFC travel due to higher pressure, that would be it.
Old Jun 24, 2010 | 07:52 AM
OK, Thanks for the input.
Hdog
Oct 27, 2014 10:52 AM
dodgediesel
14
Dec 14, 2006 09:54 AM
CSAGrey1
Mar 7, 2006 10:54 AM
turbo dreams
Jun 1, 2005 02:49 PM
