Kinda scared
Old Jun 23, 2010 | 03:10 PM
Joey62's Avatar
Kinda scared
Hey this is my first post I've been reading on here for a while and reading all this stuff and I'm kinda scared to do any thing to my stock truck in fear of really messing it up what could I do to have power but not mess it up
Old Jun 23, 2010 | 03:22 PM
BigErksG2's Avatar
Fill out your signature so we can see what you have.
Old Jun 23, 2010 | 08:49 PM
Joey62's Avatar
Ok got all the stuff bout my truck up so any sugestions would be helpfull
Old Jun 23, 2010 | 09:06 PM
ellerman's Avatar
Almost all of the stuff about your truck, manual trans or auto? In my opinion, first get a good fuel pump(FASS or Airdog) then get an Edge Juice with Attitude so you can have more power and have gauges all in one.
Old Jun 23, 2010 | 09:14 PM
Mike D's Avatar
Hey Joey, Someone gave me some good advice once. If you can't afford (monetarily or otherwise) to fix your truck, you should leave it alone. Of course I didn't listen.
Old Jun 23, 2010 | 10:29 PM
Ozoneburner90's Avatar
1. fuel pressure guage 2. replace lift pump with an aftermarket one suck as a fass, airdog, or raptor. Then you can straight pipe it and add some other junk to it..
Old Jun 23, 2010 | 10:44 PM
matthais's Avatar
lift pump will save you from failure in a stock truck
Old Jun 24, 2010 | 02:02 AM
Joey62's Avatar
Ok so what y'all are sujusting is a fass file system edge juice with attuide and the edge will have the egt's and file presure becaus I want to give it a lot of power but do it the right way
Old Jun 24, 2010 | 02:38 AM
Joey62's Avatar
Because with this truck money is not really a problem I just really want to it the right way
Old Jun 24, 2010 | 08:27 AM
high bid's Avatar
1.gauges - egt, fuel pressure, boost, tranny temp
2. fuel pump upgrade of some kind - FASS, Glacier, holley blue etc
3. exhaust - 4" minimum,
4. intake - BHAF-Amsoil, AFE, etc
5. injectors - Mach 1.6, RV275
6. electronics - Smarty, Edge, Quad, could be moved up to #2/3
7. upgrade turbo
8. repeat #5 and #7 till you run out of $$$, time or are happy.
Old Jun 24, 2010 | 08:48 AM
swordfish's Avatar
Don't neglect the Transmission. When you get up in power you will start to slip the stock transmission. Lots of reading on the forums on that topic.
I would definitely get the gauges one way or the other, especially fuel pressure. You don't want to have to put money into an injection pump if you don't have to.
I was like you, got here to the forum and was a newbie....I did a lot of reading and a lot of research. Just about any question you have has probably been answered a time or two on here already. Gain as much knowledge as you can so you are more confident with your truck and not as timid. If you are smart on your upgrades and the order you won't "mess up" your truck. Just my .02
swordfish
tfarmer96
Jan 16, 2005 03:45 PM
DMH
Jan 11, 2005 10:02 PM
Dodgezilla
Sep 29, 2004 04:41 PM
tmiller24
Feb 19, 2004 09:38 PM
BIG&BAD
Mar 11, 2003 01:55 PM
