Adjustable BOOST ELBOW
I would be more concerned about over boosting!JMO.
I woiuld wait and see how much boost you get before doing anything.
RJ
Isn't the choke hold of the HY35 around 29psi? So if you do get a J-hook, don't need to exceed this number.
A Boost Fooler is used to trick the ECM so that it does not see the increased boost through the MAP Sensor. You can be reading 28psi at the intake, however the ECM will only see 19psi lets say (or whatever the Fooler is set at). This keeps the engine fueling the same, instead of defueling and throwing an over boost code.
(Note, adding a boost elbow and boost fooler to a stock truck, without added fuel won't do much at all for power increase).
Ive read this whole thread but am still wondering....I have a Juice/attitude (bought used) without the VP tapped. My boost elbow is on its way from Edge. Will the addition of the elbow do anything for me since the VP is not tapped? The most boost I have seen is 18 or 19 pulling a trailer.
The elbow wont do much for you with the boost you are producing. You aren't getting enough boost to open the wastegate as it is, so unless you tap the wire and start making some more boost there really isn't a need for it. It delays the opening of the wastegate and if you arent opening the wastegate anyways...
Is there a reason you haven't tapped the wire yet? You can do it with one of our stealth covers and it hides the connection under the pump cover. Then you can take full advantage of all the different power levels.
Once you add the boost fooler, the little extra boost, lets say like 22ish should help a bit in power. But as the above guys said, if you really want to wake up the truck, tap the wire and adjust boost accordingly
Hdog
Oct 27, 2014 10:52 AM
dodgediesel
14
Dec 14, 2006 09:54 AM
turbo dreams
Jun 1, 2005 02:49 PM
