62/65/13ss or 64/65/13ss
Right right Im catchin what your throwin Tate.
Well Im still very undecided about weather Ill turn my Hybrid into a set of compounds or just get a bigger single in the future.
Good thing its still a WAYS in the future
It won't be a problem. I ran my 62/71 with a Smarty, HRVP and Jammer2 sticks. Spooled decently, couldn't break 1300 degrees with that setup. If you floored it from a stop and overfueled it, it will kill the spool up and just smoke. Like Dieselman said, you don't need tons of fuel to spool a turbo. You need that fuel to take advantage of the turbo once it spooled to make power. Two very different things.
dang i wish i hadnt been so ignorant then....jason
[QUOTE=dieselman2300;2578016]"you need fuel to spool it" do you realize that is the 2nd biggest myth when it comes to diesels?
1st one is drive pressure kills headgaskets.
drive pressure will kill a head gasket as fast or faster than boost press. a friend of mine had a trusk with the same mods *** mine only i had the sps 62 and he had a stock turbo he lost his head gasket and never went over 40 lbs of boost i have seen 50-60 lbs many times over the last 3 yrs and the head gsky is fine.
back on topic do not run the 65 mm wheel unless you are going to upgrade to twins later you will hate it. i have the 71mm wheel in mine with a reg 14cm housing it gets hot faster than a 65 wheel but it will not reach near as high of a peak temp as the 65 wheel.
Real short reason why.. Lets take a high boost motor with high drive pressure.. Say 50psi boost and 100psi drive pressure. Now in simple terms (because adding fuel makes it complicated) You put 50psi of air into the motor thru the intake stroke, now starts the compression stroke that 50psi of air becomes 910psi, now you get the power stoke, and on the exhaust stroke that 910psi bleeds down to 100psi. (In the complicated version the fuel ignition creates many times 910, but thats complicated).. So look at that the peak pressure we saw on the head gasket was 910psi, so how does 100psi of drive pressure make a difference? Even thou 100psi of DP is a 2:1 and horribly inefficient, and probably leading to higher EGT's than needed, its not having any effect on the HG at all.
Fire Rescue124
Oct 9, 2009 11:20 AM
Jason_K
13
May 11, 2009 08:55 AM
O.T
16
Jan 14, 2008 02:47 PM
95ram12v
Jan 13, 2008 07:48 PM
rowlrag
20
May 18, 2007 10:33 PM
