HTT 64/65/13ss vs HTT 62/71/13ss
Old 01-12-2008, 11:35 AM
O.T
O.T's Avatar
One will be the top charger on my twin set up. Super dave will sit below..
I know there are a handful of members running the 62/71/13 over the S480. Looking to hear how they perform.
Same applies to the 64/65/13 over the S480.
HP target on #2 800-850,
onetun
Old 01-12-2008, 11:49 AM
53 willys's Avatar
I am not even close to an expert on twins but from what I have read it seems like the G56 guys can get away with a pretty big turbo on top VS the auto guys???? I have been thinking a 64 with s480 would be sweet!!
I would maybe call MPI and ask the real pro.....
if you do, post up I would like to hear what you find out..
I am wanting about the same HP as you...so I am really interested as well
Old 01-12-2008, 11:53 AM
wap
wap's Avatar
Like Mark I am no expert but I would THINK that the 64 would make a lil more hp but with the 65mm wheel would have higher drive pressures and may be a lil hotter, but flow more air on the cold side.
If you want that much hp you may just want to get a 64/71/13 or if your not bent on HTT get a silver 64 wich would be 64/74/14. But your best bet will be to talk with Nathan.
Ok, just read your sig, with dual pumps and flux 4.3s I would definately think you would be ok with a 64/71/13 a 480, JMO
Old 01-12-2008, 09:25 PM
desertchecker's Avatar
nathan will probably say with the manual trans & flux4.3s 64/71/13ss will be the better call for you, like wap said lower drive pressure & wanting to push 850 hp the 64/71/13ss s480 would get you closer.
I was debating on the same issue but because I drive my truck often on the street & I have an auto.
I am going for 750-800 the 62/71/13ss/S480 will be installed next week with nathan i am just shooting for a fun truck to drive not the fastest , but fun!
anyway the HP difference between the 62 vs 64 S480 is only about 50 peak hp in favor of 64
Go For It !...
Old 01-12-2008, 10:13 PM
doug60's Avatar
drive-ability, thats why I chose the same combo.
Old 01-12-2008, 10:31 PM
I know exactly what your saying.
by the way your rig looks very nice doug60
Old 01-12-2008, 10:41 PM
Sloverado's Avatar
Well in a week or 2 I will have some hard numbers with a 66/13 over a S480 superdave. John is finishing up on with dual modded cp3 and a set of DonM big sticks.
Old 01-12-2008, 11:00 PM
53 willys's Avatar
drool!!!!thats going to be PIMP!!!
Old 01-12-2008, 11:20 PM
Sloverado's Avatar
I am hoping so. I also will be running 2 stages of nitrous. I will see how well the new HTT intercooler will hold!
Old 01-13-2008, 03:56 AM
Idaho CTD's Avatar
I'd either go with the 62/71/13 or a 64/71/13. You have a 6spd so I'd lean towards the 64 but you can always upgrade the 62 later if you need to.
Old 01-13-2008, 07:41 AM
turbopwr's Avatar
I have the 64/71/13 and s480 super dave setup. Its great, spools great. If i had it to do over i would get a 66.
Old 01-13-2008, 12:30 PM
have I heard this before ?
Old 01-13-2008, 12:45 PM
O.T
O.T's Avatar
Alright thanks guys. Looks like the 64/71/13 will be the turbo I order.
onetun
Old 01-13-2008, 04:06 PM
give nathan at MPI a call or pm
the best looking kits I have seen
he can hook you up , with turbos & plumbing etc
good luck
Old 01-14-2008, 11:06 AM
cquestad's Avatar
I am lovin' my MPI twins...
Quick Reply: HTT 64/65/13ss vs HTT 62/71/13ss
