60'ft times how to?
Old Nov 14, 2008 | 07:30 PM
heykw's Avatar
60'ft times how to?
I need to improve my 60ft times on my 01 truck. I am launching with 10 psi of boost in 4x4 and the truck wont spin the tires is torque mgt limiting the power.
60ft 2.220
102.77 mph
et 13.781
Old Nov 14, 2008 | 09:29 PM
cumminsdriver635's Avatar
You must have some torque management problems, but it could also be that you just need to leave with more boost. Try leaving around 18psi and see what that gets you. I could run a 2.0 60ft on my stock input shaft when my truck was around 300hp. That was launching at 10psi. If your turbo isnt lit when you leave you are hurting yourself. Mine launches hard at 18-20psi now, but i havent been back to the strip to see what my 60ft's are. Im guessing 1.8's.
Old Nov 14, 2008 | 10:27 PM
heykw's Avatar
it wont let me launch with any more boost? it wont build any more boost at the line?
Old Nov 15, 2008 | 03:04 AM
Must be a torque management thing then. Im not sure what all eliminates it since i dont mess with 24v's much, but get that figured out and it should be a lot better on the launch.
Old Nov 15, 2008 | 10:13 AM
skunk74's Avatar
Yep thats the good 'ol torque management. A SMARTY will help cure that problem.
Old Nov 15, 2008 | 12:03 PM
heykw's Avatar
I tried to run the smarty some one lent me at the track and the truck did not like it at all it did not want to shift? is their any other way to fix this?
Old Nov 15, 2008 | 12:10 PM
A lot of people use this:
http://www.dieselperformance.com/ind...duct/index/43P
I have heard from some that the smarty doesent work too well with an auto trans, but by using the BD Rad, you dont have to mess with the smarty. The BD RAD is $225
Old Nov 15, 2008 | 12:30 PM
01sporty's Avatar
that is weird because my truck loves the smarty
Old Nov 15, 2008 | 12:49 PM
heykw's Avatar
so that thing will get rid of the torque mgt?
Old Nov 15, 2008 | 01:20 PM
Yep. Do a search for torque management here, and you will come up with lots of information on it.
bigfoot
Jul 29, 2009 02:13 PM
green73
Oct 14, 2007 02:43 PM
Dodgezilla
Jan 29, 2003 10:47 AM
butchera
Jan 14, 2003 06:05 PM
