47rh vaalve Body install
Old Apr 19, 2007 | 06:12 PM
schoust's Avatar
47rh valve Body install
Ok Guy's I'm waiting on my Georand Valve body and converter and I was wondering what is involved with installing the new valve body? Also what type trans fluid should I use when refilling the trans is original but still shifts decent for the most part untill you hammer it that is...Thanks
Old Apr 19, 2007 | 07:04 PM
scottsjeeprolet's Avatar
the VB is pretty straight foreward, but probably a little harder laying on your back.
The trans is another story, when you take out the cross member take the bolts out then trans mount, knock the cross member up til you can slide it back towards the rear and out. Go out now and start spraying your tranny cooler line fittings with penetrating fluid. they can be a pain.
Old Apr 19, 2007 | 10:42 PM
Mslaughter's Avatar
For the fluid I used Dex III and lubeguard
Old Apr 20, 2007 | 08:19 AM
schoust's Avatar
Hey Scott, I really would like to do the whole thing but i worry about the transfer case falling,does this have to come out first?
Old Apr 20, 2007 | 01:29 PM
The job is a lot easier if you take the Tcase off. Not too difficult. Did you start spraying the cooler fittings yet?
Old Apr 20, 2007 | 01:58 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Dexron III? I'm I reading this right? Can Dex III be used in our tranny's?
Old Apr 20, 2007 | 02:39 PM
Mslaughter's Avatar
Yes, if you mix it with lubeguard. Dex III + lubeguard = ATF+4
Old Apr 20, 2007 | 03:01 PM
JPR Ram's Avatar
Oh, kewl........ Is LubeGuard available at most autoparts stores? And one last question, at ratio is it mixed?
Old Apr 20, 2007 | 03:47 PM
Mslaughter's Avatar
The only place I've checked for Lubeguard is Napa, and they had it. 1 or 2 bottles should be enough, then re-fill with the Dex until full.
Old Apr 20, 2007 | 04:00 PM
JPR Ram's Avatar
Napa.... oh right. I already buy all my filters and parts there anyways. Thanks for the tip...............
Old Apr 20, 2007 | 05:18 PM
Why not just buy the ATF+4? Heck Wally world sells Mopar +4.
I am not willing to chance it to try to save a buck.
Old Apr 20, 2007 | 05:27 PM
JPR Ram's Avatar
Well, because I have a 55 gal drum of Dex III sitting here in our shop that I have use of. I buy my own filters and my boss lets me use the motor oil, gear, oil, tranny oils, etc. etc.
Old Apr 20, 2007 | 09:02 PM
Mslaughter's Avatar
The main reason I did it is because Dave recommended it for the tranny. Also Dex III is less than a buck a qt. and lubeguard was $8 a bottle if I remember right, sure beats paying $4/qt when you need 18 qts. Awhile back infidel told me he's been using the Dex/LG combo for over 200k with no problems.
Old Apr 20, 2007 | 09:26 PM
That's what i love about this site!
Ya learn something new everyday.
I guess it has to do with what elastomer's were used when building the tranny. I always thought if you used Dex in our tranny's it would cause the elastomer's to swell and fail.
So i stand corrected.
Ravewolf
Jan 2, 2013 02:32 PM
Trooperthorn
Jan 7, 2011 12:55 AM
jj3500
Jul 12, 2009 03:59 PM
scottmn1
Jan 25, 2007 07:53 PM
