3rd gen control arms
Old Sep 21, 2006 | 02:38 PM
getblown5.9's Avatar
for those with rubbing issues on 35's...anyone swapped out the stockers for 3rd gen control arms?
my buddy gave me his when he went lifted on his 05, and the lengths and sizes all are VERY close to the same when i measured from center to center of the CA bolts. my thoughs are simply that the stock CA on a second gen flare out, where as the 3rd gen stockers are boxed and narrower, giving more room for the tire to clear.
Old Sep 21, 2006 | 06:54 PM
griggs43's Avatar
hey whats the difference in the mesurments
at least u wouldnt have that nasty u shape gutting ur tire
Old Sep 21, 2006 | 07:54 PM
when i said very close i mean it wasnt a measurable difference. thats why i think i can use them with no problems.
Old Sep 25, 2006 | 08:34 AM
just thought id bring this up, see if anyone has done this already. ill prolly play with it this week.
Old Sep 25, 2006 | 08:44 AM
displacedtexan's Avatar
NHDiesel swapped a front axle from a third gen into his seccong gen, using the new control arms, so they will work with minor modifications on the frame end. Here are his comments relating to the arms. Hope this help at least a little.
Originally Posted by NHDiesel
-Frame width is slightly different. This caused the control arms to not quite line up. They were close enough that I could get them in place easily by hand, so they should be fine. I used the '04 control arms.
-Control arm bushing sizes are different. I had to drill out the upper bolt holes to 9/16" abd the lower holes to 5/8" on the frame brackets. The '04 upper bolt length is different as well, but my original '96 lower bolts worked in the upper holes, and the '04 bolts fit the lower holes fine.
Old Sep 25, 2006 | 09:09 AM
he used the front axle as well...im just swapping CA's
with the 3rd gen frames being wider, it has me thinking now, the lowers i know will work, but the uppers may pose an issue now. as well as needing different size bolts and new cam bolts. little more research will be needed.
Old Sep 25, 2006 | 09:41 AM
Yeah, I was thinking more along the lines that that may help you know what would be involved in bolting them to the frame, that way you could worry more with how they would work on the axle end...
Old Sep 25, 2006 | 11:25 AM
all the brackets/mounting points can be modified to fit. i just need to find the proper bolt sizes now. then i think i'll me able to make it work
Old Sep 25, 2006 | 07:35 PM
griggs43's Avatar
i got different sleves for the bushings let me no ill see what i have
03CTDCO
Jun 3, 2011 09:56 PM
dieselboy59
Apr 21, 2009 02:44 PM
Doj Dewd
ABDTR #5
Jul 8, 2008 07:46 PM
wcbcruzer
Sep 7, 2006 11:01 PM
CumminsDreamin
46
Jul 23, 2006 10:37 AM
