4th gen control arms fit a 3rd gen
Old May 31, 2011 | 07:05 PM
03CTDCO's Avatar
Will a 2010 Ram 2500 4X4 upper and lower control arm fit up to a 2003 2500 4X4 ? Anyone know for sure ? Same exact length ?
Thanks in advance for the help
Old Jun 1, 2011 | 09:00 PM
Skyd Ram's Avatar
The lengths are the same but the 2010+ lower control arm bolt at the axle is 18mm instead of 16mm on the 03-09 trucks.
Old Jun 1, 2011 | 09:34 PM
03CTDCO's Avatar
Thanks Skyd Ram
The larger bolts, are these the eccentric cam bolts you are referring to ?
Those are the ones closer to the front axle. How did you find out the older
arms fit ?
Thanks again
Old Jun 3, 2011 | 02:17 PM
Skyd Ram's Avatar
Originally Posted by 03CTDCO
Thanks Skyd Ram
arms fit ?
Thanks again
Yes,
The caster adjustment cam bolts are 18mm on the 4th Gens. The only things that are different on the 2010+ trucks are those bolts, the front bolts on the leafs springs are now 18mm, and they have a few changes to the swaybar end links.
Old Jun 3, 2011 | 09:56 PM
03CTDCO's Avatar
Thanks Man
So it sounds like I just need to order the larger cam bolts. Wonder if I need to drill out the bracket holes to fit the larger 18mm bolts ? Also is the cam lobe
identical and fit in the bracket cup ?
Thanks
Blake Clark
May 17, 2010 05:23 AM
02ctd4now
Aug 9, 2009 03:24 PM
Doj Dewd
ABDTR #5
Jul 8, 2008 07:46 PM
getblown5.9
Sep 25, 2006 07:35 PM
wcbcruzer
Sep 7, 2006 11:01 PM
