3000rpm gsk question???
Old May 29, 2007 | 10:43 PM
rootremblay's Avatar
By looking at my specs do you guys think ill see a worth while power gain with the 3000 gsk. Any downsides, engine life??? How many rpm's should I try to achieve and what size washers would I need? Thanks
Old May 29, 2007 | 11:18 PM
WildBill's Avatar
You won't gain any power other than above where it now revs to. It lets you stay full throttle right until it shifts instead of having the power drop off starting at 2300 or so. The only downside is you timing could slip if the nut hasn't been re-torqued above stock spec., as it takes more power to turn the pump at higher rpms. Don't run it over about 3300 or so unless you upgrade all your valve springs.
Old May 30, 2007 | 09:59 AM
Box5's Avatar
you'll notice a big difference down low from 1250+. It pulls through the whole powerband alot better. It will definently feel like u gained a ton of power.
Old May 30, 2007 | 12:16 PM
clutch1's Avatar
wont show as much as it does on the smaller pumps
Old May 30, 2007 | 12:36 PM
superuke's Avatar
Do you have the torque specs for the nut??Would that be both nuts on both springs??
Old May 30, 2007 | 12:58 PM
thebestofindica's Avatar
On my 95 it was a night/day difference. It literally felt like a new truck. May have more affect on auto's, I'm not sure. Possibly THE best mod to date.
Old May 30, 2007 | 01:23 PM
thanks yall, from reading I think ill leave it alone a while. Ive got a few more things to tinker with to keep me busy, for now anyway.
Old May 30, 2007 | 03:31 PM
Need95-00CTD's Avatar
Throw one half inch washer in it...you won't hurt anything, it will still stay well below the rate at which valves start to float. You'll thank us after you do it. Look at the truck in my sig. I have the 4k GSK in my 95...relly woke the truck up!
Old May 30, 2007 | 04:08 PM
How thick is the washer? diameter? and Do you know where I could get some instructions on how to install? thanks.
Old May 30, 2007 | 04:26 PM
gyman98's Avatar
Look up gunracers post full explanations there
Don T
May 1, 2011 07:32 AM
Ozoneburner90
Jul 22, 2010 10:36 PM
tom25
13
May 26, 2007 06:10 PM
MR HYDROSEED
Mar 9, 2005 10:49 PM
Got Smoke?
Oct 26, 2004 03:57 PM
