24 valves with p7100 conversion
Old Jan 4, 2006 | 09:11 PM
  #31
srt20's Avatar
ok i got a question. if u were to change a 24v over to a p-pump, and u have a comp already, what do u do with the comp then? just use it for timing? or is it basically useless? what if u want more fuel with this setup? just add bigger injectors? thanks just curious.
Old Jan 4, 2006 | 09:37 PM
  #32
RCW's Avatar
RCW
The P pump does not use the comp, it would just be useless.
Old Jan 5, 2006 | 11:51 AM
  #33
24valvepuller's Avatar
you sell the comp to help off-set the cost of the conversion. and as far as selling and buying a older 12 valve, never, I know what has been done to my truck, who has done it and why. My next truck will be a 97-98 12 valve with a 24 valve head, just so when I'm at a pull and something breaks, I got a parts truck sitting in the parking lot
Old Jan 5, 2006 | 07:20 PM
  #34
jermey1980's Avatar
i got all my conversion parts just buy trading around. I traded a hot vp and drag comp for everything except the bolts for the air horn. i had the pump checked out 4000 springs and it already had full cut delivery valves in it. i know this guy very well he had 480 in the .120 lines and spacers got the cover from a junk yard for 100 bucks and the gear for 125 from a differnet yard.
Old Feb 27, 2008 | 11:32 PM
  #35
2500's Avatar
any pictures of cracked 12v 53 block?
no other reports of 12v 53 blocks cracking...
Originally Posted by cummnz4x4pwr
i converted mine over labor and all for $2500 with haisley street puller cam i just went to the wrecking yard and bought a 98 12v moter with a cracked block for $500 called haisley machine and ordered street cam and .093 oversized p-pump injector lines then took it to a local mechanic and he installed for $400
I LOVE MY P-PUMPED 24V
Old Feb 8, 2010 | 10:53 PM
  #36
Tow-mater01's Avatar
i helped my buddy with his conversion and all we did was buy the lines and he traded the head off his 97 for a head off an 05 with a cracked block and we just swapped heads... he spent about $2500 on 4kgsk, 191s, and valve springs and got a high tech 66 outta the whole deal too!!!
storx
20
Sep 21, 2006 09:02 PM
JDGPULLER
Sep 15, 2006 05:24 PM
ccowboy
Nov 7, 2005 08:30 PM
clarkoh
Aug 15, 2005 03:04 PM
Don M
Oct 29, 2002 03:00 AM
