The new P7100
Old Oct 28, 2002 | 06:43 PM
Don M's Avatar
DTR Advertiser
The new P7100
Brand new in the box from Bosch. Of course I let Joe Donnelly have a look at it first. ;D ;D<br><br>Don~
Old Oct 28, 2002 | 06:46 PM
Don M's Avatar
DTR Advertiser
Re:The new P7100
Its almost stock too. Just a mild #0 torque plate and some gov springs. Its almost too pretty to put on the old engine.<br><br>Don~
Old Oct 28, 2002 | 06:47 PM
admin's Avatar
Re:The new P7100
Ok, I have a question. How does the &quot;plate&quot; work, and where does it go, etc? Just curious. I always hear about the plates, but I have no clue about their operating theory.
Old Oct 28, 2002 | 06:55 PM
98rammer's Avatar
Re:The new P7100
ok, so you stop by and pick a new pump up without getting me one? how selfish! ;D<br><br>Jack: to put it more simply- the more the plate goes forward, the more fuel that gets forced through the injectors. the lever inside moves forward. the plate stops it. going to a low # plate--the only problem is that it burns a lot on the downstroke (black smoke) and causes the internal pressures to go up quite a bit. injectors add more fuel during the &quot;regular&quot; burn cycle and hence less smoke and lower pump pressures (with a more stock plate). <br><br>
Old Oct 28, 2002 | 07:08 PM
admin's Avatar
Re:The new P7100
Ok, so that explains it a little bit. I guess I would have to see it in action, or diagram it to fully understand, but I get the idea.
Old Oct 28, 2002 | 07:45 PM
KatDiesel's Avatar
Re:The new P7100
Can I have your old one? <br><br><br>
Old Oct 28, 2002 | 08:07 PM
drawson's Avatar
Re:The new P7100
Don What was wrong with your old one???
Old Oct 28, 2002 | 09:22 PM
Don M's Avatar
DTR Advertiser
Re:The new P7100
My old pump was roached. Way too many 4500RPM runs on it. <br>The number 4 and number 6 cam lobes were worn down, a couple of plungers and barrels were scuffed, and I was beginning to expect the roller lifters and springs were getting kinda tired. <br><br>With my old pump on the bench when I tried to turn it over, it was very difficult, almost like trying to crank an old engine over. This new pump just turns over with ease....very smooth indeed. <br><br>Im guessing the old cam with the worn lobes was killing my HP in two of the six cylinders as well.<br><br>Don~<br><br><br><br><br> <br><br>
Old Oct 28, 2002 | 09:38 PM
Superduty12v's Avatar
Muted User
Re:The new P7100
More like how much did you win off the lottery to afford a new bosch pump???? Aren't those things like $2,900.00??
Old Oct 28, 2002 | 09:58 PM
Don M's Avatar
DTR Advertiser
Re:The new P7100
There is something special about opening a box from Bosch. Money sometimes takes a back seat to Bosch stuff ;D ;D<br><br>Don~
Old Oct 29, 2002 | 03:00 AM
TxDieselKid's Avatar
Re:The new P7100
so how many cc's do they do stright out of the box, and how many do you think YOURS will do after any mods you make to it?<br><br>Glad to see your one step closer from being a &quot;pile of bolts&quot;<br><br>Andrew
HelenaTDI
May 15, 2015 10:11 AM
Deadbunny
Sep 25, 2010 08:07 PM
Mikestowing
18
Mar 28, 2010 08:07 PM
GO 4LO
Dec 31, 2002 08:08 AM
fboese
0
Dec 10, 2002 04:01 PM
